Waves V9 troubles with PT 11
So I've had this problem on ALL of my test systems since mid December. The problem being distorted playback, regardless of the size of the session or even blank sessions with nothing but Click 2.
System: Mid 2012 MBP 2.6G i7, 8G ram, booting off USB 3 test drives OS' : OSX 10.8.5, OSX 10.10, OSX 10.10.2 * All clean fresh OS installs (OSX 10.10.* have been done 4 times!) PT 11.2.2, 11.3, 11.3.1 I narrowed it down finally last night to Waves! During a test I installed Tel Ray delay, Reverb One, Magic A/B and did permission repair and reboot, tested ok. Installed Waves = distorted playback Tested on a second install with the same result. Tested on OSX Mountain Lion 10.8.5 with the same result On all systems moved Waves to the 'unused folder' restarted Pro TOols and the problem is solved. Put Waves back in the plugin folder and restart and it's still good to go. Reboot the machine and the problem returns. Again, I am able to do this currently on three systems with ALL the same results. Anyone else experience this? Am I missing anything? My ML install is optimized and rocking PT 10.3.8, the OSX 10.10.*installs are optimized to the best of my knowledge.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Re: Waves V9 troubles with PT 11
I would open a dialog with Waves if you have 100% repeatability. FWIW, my windows rig runs the latest Waves fine, so it could be an OS issue. Assuming Pro Tools and all plugins are installed to the system drive?
I'll try that again, but the last message I sent may not of gone through from what I'm guessing.
Yup, better to ask Waves tech support, they often can sort out issues in minutes.
Agreed!
Waves tech support is great. They remoted into my computer, fixed the problem, and even cleaned up some Waves "stragglers" from other versions and such. Just make sure your WUP is current. |
Thanks for the tips, I'm out of the studio until late next week so I"ll have to wait. But maybe I'll get the ball rolling this afternoon. My WUPS are all current. I'm guessing it's something with my versions. Especially since it's repeatable across different OSX versions and PT's versions.
There are probably people who know better than me about this, but the use of USB drives has always raised a flag. Maybe it's only superstition at this point--the requirements for PT10 said that USB2 is approved, but the requirements for PT11 apparently are a little more vague. I haven't seen any mentions about 3 yet. Anyway, if you're still looking around for solutions, I'd say it's worth checking out to take USB out of the equation.
Whether or not it's relevant to your situation, I'm running V9 Mercury on the system described in my sig with no issues (besides those that I'm pretty sure are Pro Tools issues!)
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
The problem is only present in PT's 11, as the one test drive has co-install and PT 10 runs fine. I'm anxious to get home and try it out. I'm really ready to wipe the system drive and commit to Pt's 11 on OSX 10.10 But so far, I'm rock solid on ML with PT10...no crashes...ever!
Sorry to hear your having problems.
I'm on Win7 Pro 64bit, and PT11.3.1 and Waves v9r25 with no issues. George Ware |
Waves V9 working fine for me in OS X 10.10.2 and PT hd 11.3 no distortion on my Mac Pro 2010 with pcie boot drive, native card, and omni. Pro Tools 11.3 and Yosemite have other issues for me but that is not one of them.
PT LE 8.0.5 + Win7 64 + Waves = Too much troubles | spray6969 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-05-2011 09:05 PM |
Waves ilok troubles part 2 | blackbirdstudio | Pro Tools TDM Systems (Mac) | 11 | 11-11-2009 07:32 PM |
Troubles with Waves user account? | kptkarl | Pro Tools TDM Systems (Mac) | 1 | 12-16-2005 07:09 PM |
Troubles...Help! | youdothat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-11-2005 10:26 AM |
troubles with M-Box | Earthworm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-27-2004 07:32 PM |
