Output Dither
I looked up dither in the Reference Guide 2020.3 and want to make sure that I have understood it correctly. It says: Quote:
Re: Output Dither
hmmm... when I print in 32 float it comes out at 32 bit float though
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32 |
Re: Output Dither
You only need to dither when you change FIXED-POINT word length (bits) from your session to bounce file.
Re: Output Dither
Thanks for your reply!
I don't want to bounce a file and know that I would need dither then if it'S a 24bit bounce. I am sending stems out to analog and use outboard inserts via my 24bit adda. Usually you would need to dither the stem outputs (auxes) and before audio goes to any outboard via inserts. The manual states explicitly that I should not do that (see my second quote, first post), hence my question: does PT automatically apply 24bit dither to its outputs or does it simply truncate? Again, I don't mean internally (printing, bussing, bouncing), I am talking of leaving the box. |
Re: Output Dither
You would never dither when you go 24bit to 24bit
Re: Output Dither
Okay, I am obviously no DAW expert, that's why I am asking here.
I am mixing and processing my audio in PT, that happens in 64bit floating point. Then I am sending it out of the box in 24bit fixed. Where exactly in PT is the word length changed from 64bit fp to 24bit fixed and is dither applied? Why do you think I would want to apply dither going from 24bit to 24 bit? |
Re: Output Dither
Going from fixed-point to floating-point to fixed-point does not require dither. You only dither when you go from fixed-point to fixed point and change word length. As in having a 24bit session and bouncing a 16bit file.
Re: Output Dither
Actually, you do need to dither when you go from floating-point to fixed. While every sample is 24 bits deep in 32-float, it's at full level and first must be converted to somewhere between 64 and 80-point fixed. You also need to dither any signal processing no matter what the depth of the source because all DSP (with the exception a decimal shift) expands bit depth.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Re: Output Dither
You can treat the noise with dither noise so that the noise sounds better as it is truncated but I don´t think it does make any hearable sense. I just dither below 24bit.
www.srs-mastering.de Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface. |
Re: Output Dither
It's not about changing the sound of the noise. You dither to prevent distortion from truncation!
Goodhertz Good Dither — a world-class dither w/ simple controls | goodhertz | AAX Plug-ins | 11 | 06-01-2015 04:41 PM |
Can Dither in Export Prefs be changed to PowR Dither | Mr. Anxiety | Tips & Tricks | 5 | 10-31-2009 10:28 PM |
192 output Dither.. output to Hear System | Jeff E | Pro Tools TDM Systems (Mac) | 10 | 07-22-2009 10:41 AM |
Apply Dither When BTD From 16-Bit Session To 16-Bit Output? | Alan Brownstein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-25-2008 06:23 PM |
PT DITHER x masterist dither x TC masterxdither x l1, q10 dither | Alécio Costa | Tips & Tricks | 9 | 02-24-2002 01:28 PM |
