Re: A little help, please: What hardware gear for PT + LOGIC + KONTAKT?
Thx Edwinstar
Question 1) No idea as yet except that having only one mic, I've noticed that my recording setup tends to always produce the same "sound feel". I just wonder if using some basic sound modifier the way uad modelized amps seem to be doing could alter this trend. And though, I'm abolutely used to making raw recordings and so would like to use these uad plugs as inserts/sends only. ... 5) Speaking of kontakt, I see it costs €399. Is the komplete bundle (€1199 including kontakt) worth it for a guy who doesn't like to upgrade his gear and banks very often? Or do Logic and PT's package do the job? In particular, what about the orchestral samples of PT12 and Logic compared to kontakt5 and komplete11? Any idea? 6) Quote:
... 8) I know the question is cheesy: have you noticed any difference of sound quality on live recordings between logic et PT...? Thank you for your help anyway. |
According to your description of the style of music you are going to produce you could find UA plug ins very useful for your applications but it´s also a question of money. The really good UA plug ins are not cheap actually even if worth the money for sure. Basically if you don´t have tons of other plug ins already and you intend to use a bunch of UA plug ins for your mixes in the future two more DSP cores will make sense indeed. If for example you want to use the fantastic Neve 88RS Channel strip on many of your tracks like you would mix on a Neve 88RS desk even 4 cores will not be enough for a middle sized session. However it sounds amazing, the closest-to-hardware-emulation I have heard. Anyway. Like mentioned already if you want to use more UA plug ins in your mixes in the future go for the Twin Duo+Quad Satellite solution. You will not regret it. Btw those satellites are on sale until March 31st and you will save $300.- on a Quad satellite if you buy it up to this date. http://www.uaudio.com/all-access-analog Quote:
Except you use tons of VIs with super large sample libraries. Then you better put these on an external anyway. If you only use an average amount of VIs with not too large sample libraries you even can have all the samples on the 1TB Flash drive too. This Apple Flash drive is that fast that you can run the system, your Pro Tools session+audio and your samples from it if you want which means no messing around with 3 different external drives. That´s why I call it a clean solution. Quote:
even more memory. I never have experienced any problems doing so. You could start out adding only 16GB to your preexisting 16GB and see what happens. If there should occur any issues you then could get another 16GB 3rd party Ram and take out the original Apple ones finally. Quote:
https://www.digitalrebellion.com/blo...sked_questions http://www.rippletraining.com/articl...nal-cut-pro-x/ https://support.apple.com/en-us/HT202413 http://www.apple.com/au/final-cut-pro/what-is/ I think with the 1TB Flash drive you can work from your internal OS drive even with video just because this drive is so blazingly fast but you will have to check it out yourself. Again I would start out running it from your OS Flash drive and see what happens. But be aware of that such a one-drive-only-solution only can work with those Apple Flash drives. With all other kind of drives, even with standard SATA SSDs you will have to use external drives for audio and video. Quote:
you can do in Pro Tools in Logic as well. Even if audio editing in Pro Tools is outstanding you may consider Logic as well if you intend to use Final Cut Pro X. Usually these guys do work well together...Logic/Final Cut, Pro Tools/Media Composer etc. Quote:
which files to save in this folder (which means to copy the data from it´s original location into your Logic project folder). If you save your Logic project as a folder and you select no files (audio files, loops, IR reverb files etc.) to be copied to and saved in your project folder, Logic will only stream the files from it´s original location. This then will work like in Pro Tools. If on the other hand you save your Logic session as a package or you save it as a folder and you select some files to be copied to and saved within the project folder, it will be like you would save a copy of your Pro Tools session with all audio files etc. Pro Tools saves sessions by default in "streaming mode" whereas in Logic you will have to choose manually in which "mode" you will run your Logic session. Either in "streaming mode" or with all your used files copied to the project folder again. If you do nothing Logic will save sessions as a package with copies of all files (loops, audio, IRs etc.) included by default. What this guy is saying is that if you are not moving your Logic sessions to other systems (where you need to take all your files with you) you better run your Logic sessions in "streaming mode" only. Just because if you save it as a package or select some files to be copied to and saved in your Logic project folder too this data will double up on your system and therefor waste storage space on your drive. Quote:
drivers etc. And like mentioned before I also think UA plug ins will work great with your style of music. You still can buy an I/O extension later if you will need more than 2 inputs at a time in the future. Last edited by VRW; 03-08-2017 at 05:05 PM. |
Don't know where you read that but that's pure horse manure. Adding extra ram doesn't void AppleCare if you're worried about that. What you should do is to scrap the existing memory and add all new memory modules of the same size/specs/manufacturer. OWC is you best bet for Mac compatible ram - they know what they're talking about. You'll more likely than not run into two amounts of ram - one is the Apple spec and one is the real world spec - trust the latter.
1.) if you can afford it, why not play with the UA universe. It makes a lot of sense for guitar and bass players with no amps.
5.) komplete is great! but you'll get pretty far with the built in sounds, especially in logic. another favorite: spectrasonics omnisphere. 6.) samples usually get modified in the sampler and remain untouched in the source. 8.) they feel different to me and therefore also seem to sound different. but i never did an A/B and both can make Hit Records! Gesendet von iPhone mit Tapatalk |
Logic Pro 9.1 with TDM Hardware | TornadoTed | Pro Tools TDM Systems (Mac) | 14 | 02-05-2023 02:25 PM |
Logic Pro X and HD 192 Hardware | DAS-Mike | macOS | 2 | 08-14-2014 09:44 AM |
Logic with PT hardware | gw sound | Pro Tools TDM Systems (Mac) | 23 | 09-15-2005 03:05 PM |
Running Reason & Kontakt Through Outboard Gear | Orange Worker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-24-2004 09:50 AM |
Logic and PT hardware | Lion | Pro Tools TDM Systems (Mac) | 1 | 12-15-1999 10:44 PM |
