Upgrade to 003 question
Hi!
I would like to know if u can set 64 buffersize on the 003 and what latency you get with for example NI:s standalone VI:s. I have an Mbox2 Factory today. I would like the more inputs and some new plugs on the 003 but mostly Im hoping for lower latency. Thanks for any feedback. /Micke
I voted at www.deardigi.com Drummer of Yamaha Birch Absolute Custom Nouveau Vintage Natural - Zildjian K Custom Dark - Sabian HH Macbook (2009-01) 2.0 GHz 4 GB Intel Quad (2007-07) Q6600 2x250 4 GB PT 8 Digirack 002 Monitors: JM-Lab Electra 906 & SW900 driven with Pioneer Reference M-90 "Semiprofessional user" |
Re: Upgrade to 003 question
jamtime, this won't answer your question but sunburst and i were talkin' about 'just what' allows one to set the buffer down to 64??!!! 'cause in his tests with his new quad and his 002, he COULD set his buffer down to 64. yet on my 002, i CANNOT. 128 is my lowest. and i even mentioned your tests with your new system where i told him you only got down to 128 (i think that is correct). so along with your initial question, i would like to know WHAT DETERMINES when a setup CAN be set to a 64 buffer size??? could it be the amount of memory??
EDIT: i say memory 'cause you tested with 2gb (i think) and sunburst tested with 4gb. anyway, it's a guess...
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
All settings are 24 bit 002,002R and 003 44KHz 64/128/512/1024 48KHz 64/128/512/1024 88KHz 128/512/1024/2048 96KHz 128/512/1024/2048 Original MBOX and Mbox2 Mini 44/48KHz 128/512/1024/2048 What sample rate and bit depth are your sessins Micke/? Mykhal I know we talked about it, did you ever check to see what the results were when you opened a NEW 44 or 48KHz 24 bit session? Edit: Micke I will run over to Guitar Center and check the 003 for you, It only about a KM away
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
The 003 Console over at Banjo Hut is the same as my 002, I didn't check a 003R but there is no reason to beleive its different.
What we need to be doing is filling out feature request forms for buffer 64 at all sample rates and adding of buffer 32
Sunburst, Mykhal, I love you!
I have the Mbox2, not PRO. So I can only choose 128 at the lowest on any configuration. Have only 44 and 48 to choose from. It doesnt support 96. And even at 16 bit, 128 is the lowest. Yes it would be great to test 64 or even 32. If it works, then it works. If it doesnt, it doesnt. But maybe Digi wants to have more gold for the users that buyes the more expensive stuff. Like many car manufactors who downchip some motors to differentiate the modelprogram. Not unusual. Still curius about the latency times that any Virtual Instrument will report at 64. Maybe even the FW interfaces will report lower latency at 128 than my USB at ditto. I can never get under 9 ms. /Micke
Mykhal!
Did you test to set the buffer to 64 while 44/48 was choosen? If so, do you have any standalone virtual instrumets that could tell what latency it gives at that setting. Or anyone? /Micke
Hi!
Just tested my 003 factory. In 24 bit 96khz the lowest buffer is 128. Didnt test 88.2. 48 khz allows 64 buffersize. All my VI` says "dly 10". Guitar rig in a mono audio track says "dly 0" VI`s -Hybrid, Analog factory, BFD, Battery. I will reccomend 003. As a drummer you need the I/O`s Rossi
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100 |
Could u please run Analog Factory and Battery standalone and set the buffer to 64 and look what latency these app shows. That would be really helpfull! /Micke
I didnt install the standalone option for battery, but with analog factory standalone I get at 96 Khz, 64 buffer, 0.7 ms delay
Rossi
Mac Upgrade Question | Rayvenx2208 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-24-2010 08:53 AM |
Upgrade question - can I use mbox2 micro upgrade on 002 system? | spreston | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-22-2009 11:22 AM |
upgrade question | ggmmss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-18-2006 08:55 AM |
To upgrade, or not to upgrade? 'Tis the question.. | knewbee | Pro Tools TDM Systems (Mac) | 5 | 03-07-2005 09:09 PM |
to upgrade or not to upgrade, that is the question | paul m | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2004 12:01 PM |
