Slate out/Talkback volume control
The manual states that the Slate out level should be controlled by the Talkback volume pot... which isn't the case on the C24 I'm using -- is the manual correct and I have a bad pot.. or is the manual incorrect?
Rail
Re: Slate out/Talkback volume control
Rail,
If you go out the Aux Out can you control the volume using the knob? I think the Aux outs are controlled by the volume, but the slate out isnt- I'll test that too. Either way it might be a good test to check. Rob-
www.carvelstudios.com |
Aah.. I believe you're right.
Thanks. Rail
PT crash when accessing Slate Trigger 2 from Artist Control/Mix | ThomasHQ | Artist Series | 2 | 01-20-2014 12:54 PM |
Pro Control Talkback switch | GrantFM | ProControl, Control|24, Command|8 | 0 | 12-02-2009 11:44 AM |
pro control, surround, talkback and cue mix | StaticStudios | Post - Surround - Video | 4 | 11-17-2007 06:18 PM |
New talkback mics for D-Control | oscillations | ICON & C|24 | 6 | 10-04-2005 09:48 AM |
Talkback mic on the control 24..How to.. | trelobas | ICON & C|24 | 2 | 08-29-2003 09:44 AM |
