Old 03-21-2008, 05:50 AM
s_hull s_hull is offline
Default IMPORT SESSION DATA TRACK ORDER ISSUE
I'm really sorry if this has been touched on before. I did multiple searches on this issue to avoid redundancy and didn't come up with anything, but I'm sure this isn't the first time this has been an issue with people.
I have DV Toolkit 2 specifically for the enhanced "import session data" features you don't get with vanilla LE. I'm working on a CD that was recorded in Logic and sent to me in various folders corresponding to individual songs. Each the folders of course contain all the wav files (with all the instruments named consistently among the songs) for a song. I created a PT 7.4 session with one of the songs with a LOT of buss routing, using almost all the available busses. When I finish this song and want to mix another song, I create a new PT session out of the next folder's data, then import the session data from the first PT session and all the tracks are totally out of order. Is there some way to retain the track order when doing an "import session data"?
I quite sure this is a newbie issue, so sorry for the redundancy. Hopefully this will benefit other people as well.
Thanks
Scott
Old 03-21-2008, 06:06 AM
Phil Ogden Phil Ogden is offline
Default Re: IMPORT SESSION DATA TRACK ORDER ISSUE
I've no experience of OMF transfer if that's what you're talking about here. However, would it not be better to create a session template with the correct track order and routing in place and import the (time stamped) WAV's into that?
http://www.myspace.com/philogg
Multi-Out Synth tempate and Session Data import issue. Dave Modisette Pro Tools 11 3 11-27-2013 12:47 PM
match track in Import session data window issue dgoodi22 macOS 5 09-06-2013 01:35 PM
Import Session Data issue/question budster Post - Surround - Video 8 08-05-2012 11:20 PM
Import Session Data Issue PT8 Themystro1 Pro Tools TDM Systems (Mac) 5 12-04-2009 11:50 AM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 07:35 PM
