Old 06-21-2016, 01:21 AM
Camilo Toledo Camilo Toledo is offline
Default Pro Tools 12 on Win10 and C24
Experiencing problems with my C24. I am getting the "An error occur while trying to establish an Ethernet connection" the diginet32.dll problem. I have tried some of the fixes I found here for Win 7, and also on the Avid site with no luck. Has anyone gotten this issue fixed and how you did it?
Just upgraded to Pro Tools 12 HD on Windows 10/ HD Native PCIe card and a 16x16 I/O. Home made PC/Asus x99/i7 5820k / 32 gigs corsair/SSD system and SSD audio.
After rebuilding my PC, installing software etc. connecting a few pre amps which I used with a patch bay Pro tools runs with no issues and everything seemed normal, recorded a few tracks, ran old sessions. I can monitor with a Central station.
I have all the db25 cables for the C24 connected. However, I decided to leave the one Ethernet cable connection for the C24 for the last step, since I thought it was the easiest thing to do... and that turned out to be the problem!! Any suggestions?
Camilo Toledo
Old 06-21-2016, 02:45 PM
Default Re: Pro Tools 12 on Win10 and C24
Got it to work.
Camilo Toledo
Old 07-30-2016, 07:00 AM
soulsound_post's Avatar
soulsound_post soulsound_post is offline
Hey Camilo, I have the same problem ! any tips please ?
Old 08-12-2016, 07:08 PM
deuc224 deuc224 is offline
Bump!!!!! Need help with exact set up PTHD, w10 pro and c24.
Old 02-17-2017, 08:15 AM
paulmellors paulmellors is offline
Same issue. Just migrated to a PC and can't connect to C24
[B]Pro Tools 2018.4, C|24, X32 Rack, Win 10, Waves 10, Komplete 11, composers collection
Old 02-22-2017, 02:03 PM
Windows 10 will uninstall the Avid driver for ICON/C24 because it is unsigned.
It looks like it is installed in the network adaptor, the protocol is ticked, but it is actually uninstalled.
To install you MUST disable secure boot and keep it disabled. This allows the driver to be installed and the C24 works perfectly.
Xpand2 UI Corrupted in Win10 cubdukat Pro Tools | First Discussion 1 07-03-2016 06:34 AM
What version of PT12 are you using? Are You using Win10? senghor Pro Tools 12 18 06-22-2016 10:01 AM
Pro Tools 10 & Komplete 8 Can't load plugins [Win10] Oglon3r Virtual Instruments 3 04-19-2016 06:43 PM
Fast Track C600 Win10??? rino2 FireWire and USB Audio Interfaces (Win) 2 12-21-2015 03:58 AM
