Special Characters in PT11 not supported?
Is there any reason, that the german characters like ÄÖÜß are not supported for Track names or filenames?
Actually i have to deliver some 1000 files containing these characters and do not want to rename them manually in the finder! |
Re: Special Characters in PT11 not supported?
oh, forgot to mention: it worked in PT10!
Known issue.
See here: http://protools.ideascale.com/a/dtd/...ps/112637-3779 When spotting files with soundminer containing umlauts to PT11 the clips will be labeled with weird math symbols (square roots and others). Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
I experience the same when it comes to naming session files and exports. I'm on a Danish os running osx 10.8
Did you talk to your talkbox today? |
It Works in pt 11.1!!! Yeah!
Hello. In a similar vein, I recently came across the fact that if you have a file with a slash character on it, Pro Tools 11 will not read it and the file will be unaccessible from the Workspace. Once you take out the slash the file is accessible again.
I created a thread about it. http://duc.avid.com/showthread.php?t=349693
froyo |
and its gone again in PT 11.1.3 - when opening a session using Clip names with Umlauts ÄÖÜ, i get a warning saying "files are missing" - when selecting "find an relink" theses files magically appear as found??? Why is that?
Frank.
Did you Rename the Session or the Clips? Do you mean once i Rename a Clip in 11.1.3 with Umlauts, it will reopen Fine? Bad for older Sessions then ;(
indeed - saving & reopening the relinked session in 11.1.3 DOES work! The Problem only occurs opening an older session conatining clip names with umlauts...
003 and other legacy interfaces supported in PT11 | JohanW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-09-2013 10:35 AM |
clear special vs. cut special | Frank Kruse | Post - Surround - Video | 2 | 08-09-2012 06:40 AM |
Unallowed characters | Ramtitam | Pro Tools TDM Systems (Mac) | 5 | 10-11-2010 09:07 AM |
characters | bongo_x | Pro Tools TDM Systems (Mac) | 0 | 07-02-2006 04:00 PM |
Only 27 Characters? | mizieg | Pro Tools TDM Systems (Mac) | 2 | 01-30-2004 12:42 PM |
