Old 02-04-2003, 09:40 PM
307 307 is offline
Default Time code display
Did the protools LE can display bars samples and mins only? can it display the timecode like the TDM version? If not did there any way to do if we wish to run with timecode not bars and samples.
Thanks a lot.
Old 02-05-2003, 12:35 AM
gerax gerax is offline
Default Re: Time code display
For bars and samples simply set the transport window to show that on the display (under the "transport window shows" menu), unfortunately Time Code is not available yet for LE altough some users have a template set up that can allow to work with time code, try to do a search on it.
Hope this helps
L.G.
Time Code display Sync I/O efisch Post - Surround - Video 2 07-11-2011 11:17 AM
Moving Start time and time code with it... KungFuLio Pro Tools TDM Systems (Mac) 15 08-05-2009 08:42 AM
QT time code won't match to PT time code in PT LE jah-d Post - Surround - Video 4 07-28-2006 10:44 PM
couldn't lock to Time Code in time for vid record benderbro Post - Surround - Video 3 12-28-2004 11:21 AM
Time display problem Jules ProControl, Control|24, Command|8 5 01-05-2000 05:33 PM
