master and slave sync problems
ok i have a tmd1000 digital mixer going to a tascam if-tad converter. which takes tdif and converts it to lightpipe. now im getting errors on the box that signify that i either have 2 masters or 2 slaves. can ne one tell me how to set up digi001 as master and or slave. thnx in advance
Re: master and slave sync problems
bump...
yikes, thats a tough one.
Well it should be a matter of going to the Setup menu in Pro tools, select 'hardware', and choose sync mode as 'optical' or 'internal' (depending on whether you're recording to or from the 001), and set your sample rate. Also in the 'other options' box make sure your optical format is set to ADAT.
Hope this helps Bill.
billrog |
it worked bill!!! thnkx...
Pro Tools (Master) sync (MPC 2500 Slave) troubles... | Connecticut | macOS | 2 | 07-06-2011 06:16 PM |
Sync Pro Tools (master) and Logic (slave) | tonicjeff | Pro Tools TDM Systems (Mac) | 2 | 02-22-2008 08:56 AM |
Master or Slave | smmdrum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-01-2003 09:37 PM |
sync triton as master to pro-tools as slave? | eddybertrand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-13-2001 01:21 PM |
slave or master | Mike Glenn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-04-2000 06:34 AM |
