Pro Tools LE 8.0.3 + Digi003 freezes with Win7 Pro x64
I've used Pro Tools for years without using Digidesign "supported" hardware. I've always used USB drives at 5400rpm without any issues at all. I've used whatever random (Ricoh) firewire port that was on my computer, without any issues at all. I just recently plunked down $100 for a SIIG FireWire Express card, and another $200 for a 1TB FreeAgent FireWire/7200rpm drive to use with Pro Tools LE 8.0.3 on my fresh install of Win7 Pro x64.
I know that Pro Tools is still in BETA for Win7 x64, so if there's no fix for this that I can try, consider this a report to try to fix it by the time it comes out of BETA. I have not had a chance to play through an entire session without Pro Tools freezing. In the middle of playback, the meters stop jumping, but playback continues. It's only when I stop playback that everything freezes. EVERYTHING freezes, and I have to hard reboot my computer. All my Playback Engine settings are default right now. I've tried raising the settings, lowering the settings, nothing has had an effect. Number of processors, HW buffer size, disk cache, etc... nothing saves it from freezing. Ironically, Pro Tools has never RUN BETTER, while it's running. When it works, it's the most responsive, slick and speedy that I've ever seen Pro Tools run, which I guess can be thanks to the faster drive and better firewire card. Oh, and the time it takes to load a session has easily doubled... but closing a session takes no time at all. My reliability and stability of Pro Tools has gone wayyy downhill, to the point of being un-usable. I've tried trashing the prefs. I've tried deleting the Databases folder. Is there anything else I can do? Has anyone had any similar problems? I have a Lenovo T61 laptop, Core 2 Duo 2.5ghz, 4GB DDR2 RAM, Windows 7 Professional 64-bit, SIIG FireWire Express Card, FreeAgent Xtreme external drive, Digi003 Rack, Pro Tools LE 8.0.3, Waves Mercury, Nomad Factory Integral Studio Pack, etc. All plugins are compatible. Sandra report to follow.... EDIT: I've never had to do a Sandra report before..... does it usually take more than half an hour? Or did THIS freeze too? |
Re: Pro Tools LE 8.0.3 + Digi003 freezes with Win7 Pro x64
But PT still runs smooth with the Waves GUI open... |
no... really... is a Sandra report supposed to take like 45 minutes? It hasn't shown me anything yet, but the green clock thing in the corner is still rotating....
here it is. SiSoftware Sandra Computer Model : Lenovo 7658CTO Workgroup : WORKGROUP Host Name : Matt-PC User : Matt Processor Model : Intel(R) Core(TM)2 Duo CPU T9300 @ 2.50GHz Speed : 2.5GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Lenovo 7658CTO BIOS : Lenovo 7LETC5WW (2.25 ) 11/14/2008 Bus(es) : PCI PCIe IMB PCMCIA CardBus USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DDR2 SO-DIMM Chipset Model : Lenovo T61 Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 4GB DDR2 SO-DIMM Shared Memory : 8MB Memory Bus Speed : 2x 333MHz (666MHz) Memory Module(s) Memory Module Memory Module Video System Video Adapter : Mobile Intel(R) 965 Express Chipset Family (8 SM4.0, Integrated Graphics) Graphics Processor Storage Devices Disk 538.6MB : 514MB FUJITSU MHW2160BJ G1 (160GB, SATA150, 2.5", 7200rpm, NCQ, 8MB Cache, 387MB Flash) : 149GB (C:) (E:) ST31500341AS (1.5TB, FireWire/1394/SATA300, 3.5", 7200rpm, NCQ) : 1TB (F:) MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ-862 (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Media (E:) : 45GB (NTFS) @ FUJITSU MHW2160BJ G1 (160GB, SATA150, 2.5", 7200rpm, NCQ, 8MB Cache, 387MB Flash) FreeAgent (F:) : 1TB (NTFS) @ ST31500341AS (1.5TB, FireWire/1394/SATA300, 3.5", 7200rpm, NCQ) Win 7 (C:) : 98GB (NTFS) @ FUJITSU MHW2160BJ G1 (160GB, SATA150, 2.5", 7200rpm, NCQ, 8MB Cache, 387MB Flash) ServiceV002 : 6GB (NTFS) Optical Drive (D:) : N/A @ MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ-862 (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Lenovo T61 Audio Device : Lenovo ThinkPad T61 Audio Codec : Analog Devices AD1984HD sound chip Audio Codec : Conexant HDAudio Soft Data Fax Modem with SmartCP Serial Port(s) : 1 Disk Controller : Lenovo ThinkPad T61 Disk Controller : Lenovo ThinkPad T61 Disk Controller : Intel Flash Cache Logic Chip USB Controller 1 : Lenovo ThinkPad T61 USB Controller 2 : Lenovo ThinkPad T60 USB Controller 3 : Lenovo ThinkPad T61 USB Controller 4 : Lenovo ThinkPad T61 USB Controller 5 : Lenovo ThinkPad T61 USB Controller 6 : Lenovo ThinkPad T61 USB Controller 7 : Lenovo ThinkPad T61 FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) FireWire/1394 Controller 2 : Lenovo R5C832 IEEE-1394 Controller CardBus/PCMCIA Controller 1 : 45052 RL5c476 CardBus Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : hp psc 1200 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Adobe PDF Converter (4000x4000, Colour) Network Services Network Adapter : Intel(R) 82566MM Gigabit Network Connection Wireless Adapter 1 : 11a/b/g Wireless LAN Mini PCI Express Adapter (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 3.1 |
it actually got worse. i got a blue screen. seriously.... a BLUE SCREEN? I haven't seen one of these since Windows 98!!! Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.256.48 Locale ID: 4105 Additional information about the problem: BCCode: 50 BCP1: FFFFF8810C7BA3D8 BCP2: 0000000000000000 BCP3: FFFFF880073DAB1D BCP4: 0000000000000005 OS Version: 6_1_7600 Service Pack: 0_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\122809-44319-01.dmp C:\Users\Matt\AppData\Local\Temp\WER-52119-0.sysdata.xml Read our privacy statement online: http://go.microsoft.com/fwlink/?link...8&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt |
I looked at the crash dump file, and it concluded that:
Probably caused by : dg003.sys ( dg003+db1d ) |
I'm not entirely sure what you mean. I have 8.0.4b drivers installed. I think I had it on at all times. Does it really make a difference?
in the dumps i've looked at that involved the 8.0.3 drivers and dg003.sys (probable cause), i would suggest tryin' the legacy F/W driver if you haven't already. 8.0.3 and its' drivers seem to be more stable on the legacy driver. at least that's been my experience while testin'
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
PT 11&10 w/PC Laptop (win7) & DIGI003 Which ones? | sharpo07 | Pro Tools 11 | 0 | 11-07-2013 10:35 AM |
PT Freezes ... too often! (MP9,FTP, Win7 64) | krabbencutter | Pro Tools M-Powered (Win) | 5 | 04-19-2012 09:21 AM |
digi003 factory win7 64 bit freezes or blue screen | hkk009008 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 02-07-2011 09:02 AM |
New laptop-windows freezes when starting a session on win7 64 | reltucdc | Pro Tools M-Powered (Win) | 0 | 10-28-2010 09:55 AM |
pro tools not able to connect with digi003 | dopemoney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-06-2009 08:47 PM |
