Old 03-16-2019, 10:47 AM
spock999 spock999 is offline
Default Question for GURU about Pro Tools Inserts
I have a Question for the Pro Tools GURU about Inserts
I just trash all my Pref I start a new session with just the minimum but it`s still say that I have inserts in 1-2 and 21 - 22
Can someone explaine that one to me
Thanks for your time
See Attachement
Your eyes can deceive you don't trust them , Mix with your ears
Old 03-16-2019, 11:09 AM
Default Re: Question for GURU about Pro Tools Inserts
Never mind I got it
Old 03-17-2019, 09:47 AM
Bookerv12 Bookerv12 is offline
Originally Posted by spock999 View Post
Never mind I got it
And?
bookerv12
Old 03-17-2019, 12:07 PM
Emi's Avatar
Emi Emi is offline
A strange thing happends to me. I have output 8 connected to an external RTA, but I can’t use the in/out 7 as an insert unless I inactivate out 8. I would have to modify I/O and turn 7-8 stereo path into mono paths to work.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 03-17-2019, 12:52 PM
filmixer filmixer is offline
See Attachement
I/O setup isn't in Prefs. It's a different file. If you have "Last Used" selected when you start a new session, that's what will show up. Namaste.
Mark Ettel C.A.S.
Old 03-17-2019, 01:40 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Originally Posted by Bookerv12 View Post
And?
just speculating but perhaps PT loaded ""last used" I/O option when creating a new session. adding perhaps PT remembers this even with a trash preferences procedure.....
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
RegEx-guru question Frank Kruse Post - Surround - Video 9 04-25-2018 04:55 PM
Pro Tools HD inserts question jrmintz macOS 2 09-10-2013 12:49 AM
A question for a wiring guru. IO Composer Post - Surround - Video 3 08-06-2004 04:30 PM
Question for midi guru old timers Donny MIDI 1 02-21-2004 06:52 PM
A Midi question for a Guru clarpark Pro Tools TDM Systems (Mac) 3 02-22-2003 04:10 PM
