Old 03-13-2019, 01:47 PM
buddyrocker buddyrocker is offline
Default Re: Getting Pro Tools to recognize USB-MIDI Interface - Setup
Originally Posted by Bob L View Post
Have you corrected the Connections as in post #2?
Have you put the Instrument or MIDI track into RECORD?
Yes on both counts. The "MIDI Monitor" software recommended shows that there is a signal being recognized, so it seems the issue is in PT.
Image of MIDI coming in on Chan 1
I did arm the track, but no dice
Old 03-13-2019, 01:49 PM
Originally Posted by Southsidemusic View Post
LOL
HUD = Head Up Display as in one of my Porsches that displays info on the windscreen i.e HUD
https://en.m.wikipedia.org/wiki/Head-up_display
Haha, jeeeeesus, one tiny spelling error!!! Corrected, thanks
Old 03-13-2019, 02:47 PM
Southsidemusic's Avatar
Just messing with you my friend
Did you get a signal on the Virtual Instrument or midi track or is it only darkness?
Also make sure Midi Thru is enabled under options I think in PT.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-13-2019, 03:14 PM
ha! All good, I deserved it!
So Pro Tools is not recognizing the MIDI interface. I'm really at a loss. All the videos I've watched are set up exactly the same, and I can see that MIDI signals are being input via USB, but crickets on PT.
MIDI Thru is checked
Old 03-13-2019, 04:44 PM
ChuckS ChuckS is online now
There is a difference in terminology when using external MIDI keyboards. Your USB connector is a MIDI ‘interface’. You connect the keyboard as a MIDI ‘device’ to a MIDI ‘interface’. You have not created that relationship in AMS. Try creating a new device XP-60 in AMS and make the connections in AMS with the up/down arrows on the bottom of the ‘interface’ to the top of the ‘device’. Then the device XP-60 will show up in PT. Old school MIDI.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 03-13-2019, 05:21 PM
Thank you. Just to confirm, even though MIDI Monitor can see the keyboard key strikes, Pro Tools needs to have it set up in AMS?
Old 03-13-2019, 05:30 PM
I have always set up old keyboards and rack devices that way in AMS and they worked. Never tried direct via an interface port unless the keyboard had its own USB connector.
Old 03-13-2019, 08:57 PM
YYR123's Avatar
YYR123 YYR123 is offline
I used to use usb (off keyboard) to computer and get PT to detect it inside the software- always worked but i recently in the last year moved to one of these https://www.sweetwater.com/store/det...midi-interface
Midi latency is a real thing and this device helps out tremendously
Daniel
Old 03-14-2019, 01:27 PM
Thanks! So I set up the AMS like this:
I then tested it, and the XP-60 was getting signal and was successful. Went into PT and set up two different Instrument tracks like this:
Armed them and hit keys on the Roland XP-60, and nothing. This is so frustrating. I've never had this much issue getting MIDI set up. Regardless I've never used a USB Interface, but all signals point to it working.
What the heck?
Old 03-14-2019, 01:31 PM
That runs off USB 2.0?
PT will not recognize my MIDI interface [SOLVED] JMUMRD MIDI 3 05-19-2015 04:17 AM
Pro Tools won't recognize interface. wedgewedge Pro Tools 10 3 04-30-2014 11:55 PM
Pro Tools 9 HD won't recognize my 192 interface innerbooty Pro Tools TDM Systems (Mac) 12 11-17-2013 01:39 PM
PRO TOOLS 10 + HD2 + 96 IO interface not recognize eliomusik Pro Tools TDM Systems (Mac) 14 09-28-2012 11:34 AM
Audio/midi setup doesn't recognize my mbox 2 academic? jpp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2009 10:49 PM
