#31
Re: 8.0.4 doesn't work
Quick Reply, havent read all info:
Assuming you have a firewire interface: Did you do an "idiot" check (sometimes very helpfull Check the Firewire chain: Is your FW controller listed as working properly in Device Manager/ properly installed? Did you check the FW cable, use another one if available (no damaged cable, not inserted?? Did you led the current bleed out of the PT - interface, Power cable out and turn on your PT interface... Corrupt FW drivers? Your PT interface card is damaged or your FW controller? Check PT with interface on another PC if available to separate Hardware from Software issues Hopes this helps good luck! |
#32
i can answer your question
because it happend to me i removed the driver first and thats what the problem is let the install detect your current driver then it will uninstall it then reboot then resume installl and you should be fine |
#33
How is Reaper? I've had so much trouble with Protools is redicuouls. I'm about ready to change to something else. How does Reaper compare to Protools? Please elaborate if you can because this would be a huge help to me. Thanks!
#35
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#36
If memory serves, and it does, last time "GM" needed help he was just as testy with us for needing information to make an educated assessment. Or, "Those who fail to LEARN from history are condemned to REPEAT it."
Perhaps a switch to decaf is in order????? |
#37
But it is easy brother Mykhal... all are welcome. *sinister laugh*
Audio Suite plugins that work in 10, do they work in 11? | David Sandwisch | Windows | 1 | 08-10-2013 08:14 PM |
The plugs that WORK and DON'T WORK on 7.0 | The Mink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 02-10-2006 10:12 PM |
New Mic won't work | DougSt.Louis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-12-2002 09:06 AM |
How does Direct Connect work?? (Does it work well??) | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-18-2001 08:13 AM |
