Instrument Track Grayed Out
I've been having a reoccurring problem with playback of VI drums. I'll record the drums on an Instrument track, save and close the session, but when I come back later to open the session, the Instrument track with the MIDI notes is grayed out.. and won't playback. If I create a new MIDI track, set the output to the Drum VI and drag the grayed out Instrument track to the MIDI track it'll play.
Has anyone had this problem and figured out what's causing it? It's starting to get really frustrating. Thanks. |
Re: Instrument Track Grayed Out
Go to View>Mix Window Shows> and check the "Instrument" option. That adds a row across the top of the MIX window that shows the midi>instrument assignment. Odds are that its forgetting what instrument the midi should be feeding(and resetting to the plugin should fix it). This may be a bug as I have read about it a few times
Instead of creating a new track, did you try changing the routing for the MIDI on the instrument track you already have? This is a problem that has been reported.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thanks. Ill check out both methods.
Brian is correct. The first place to look is the MIDI assignment on the instrument track. I've had this happen as well. It a known issue and there doesn't seem to be any rhyme or reason to when or how it happens!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
I'm losing instrument assignments on song reloads quite frequently..I have learned to make a note of which assignment to use on the track (this can all be saved with the project in the notes section) so i can set it manually again if need be (and it need be, a lot unfortunately)..
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
Thank you for this!
iMac 27"; 4.0Ghz Intel Core i7; 16GB RAM; Pro Tools 2019.12 |
Inst Track grayed out. Why? | orvillej | Pro Tools 12 | 6 | 04-08-2017 08:56 PM |
Instrument track grayed-out when I open project? | ergalthema | Pro Tools 11 | 1 | 11-14-2016 04:35 AM |
midi instrument track grayed out...??? | gamblor | Pro Tools TDM Systems (Mac) | 10 | 02-14-2012 12:00 PM |
New audio track...Record button grayed out? No response... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-18-2011 03:58 AM |
Mono Instrument Track VS Stereo Instrument Track | mbox2issue | Tips & Tricks | 8 | 04-20-2009 04:21 PM |
