Old 01-16-2018, 04:47 PM
laki laki is offline
Default S6 Randomly Disconnecting
Hi all,
I have an S6 M10 running 3.7. It randomly drops its network connection. When it does, I get a message on the MTM saying "Workstation has unexpectedly disconnected". If I restart WSControl, it comes back.
I have attached a screenshot of the trace log from WSControl.
Anyone else have this? Its been happening a couple of times a day. I have replaced the network cable.
Figured I'd crowd source an answer before opening a support ticket.
OSX 10.12.6 Late 2013 Trash Can Mac
PT12.8.0 HDX
MTRX
Cheers,
Laki
Old 01-17-2018, 02:35 PM
creativecontrol's Avatar
Default Re: S6 Randomly Disconnecting
Greetings,
These are usually networking issues. Are you using the internal DHCP server of the master module or an external DHCP to assign addresses? Are you using multiple NIC's on that particular workstation for Internet, Surfaces, Satellite, Shared Storage, etc?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-17-2018, 07:13 PM
Originally Posted by creativecontrol View Post
Greetings,
Jeff
Hi Jeff,
Thanks for your response. Yes we are using the internal DHCP server on the MTM. Also using multiple NICS. The S6 is by itself on En0 of the Mac Pro. Everything else (Internet, Shared Storage, Satellite, MTRX) is on En1 of the MacPro.
I have 5 other S6 suites with the identical setup. No issues there.
Cheers,
Laki
Old 01-18-2018, 08:02 AM
Thanks. So - a single workstation on this S6, correct? Also, are you using Port 2 on the MTM (default) for DHCP assignment?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-18-2018, 01:27 PM
Yes. Single Workstation connected to S6. Using Port 2 on MTM. I’m getting the IT fellas to check the cabling between the desk and the CPU in the server room.
It’s so random. Didn’t do it yesterday.
Old 01-18-2018, 07:24 PM
EddieJones's Avatar
We would recommend switching to Port 1 on the MTM first, its a different Intel chipset and tends to be more reliable. Once you switch the cable you have to reconfigure the network on the surfaces settings page.
Old 01-23-2018, 06:10 PM
Thanks Eddie. I will try this once we are sure that the problem is not external.
Old 01-24-2018, 01:11 PM
quadraphonics quadraphonics is offline
I get this sometimes when unplugging a USB flash drive from the front USB port on my Mac Pro (Cheese grater) . I have to restart both the S6 and the Computer to get connection re-established.
Randall
Originally Posted by laki View Post
Hi all,
PT12.8.0 HDX
MTRX
Cheers,
Laki
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 07-31-2018, 10:45 AM
jdh95 jdh95 is offline
Hi all,
PT12.8.0 HDX
MTRX
Cheers,
Laki
Did you ever get your disconnect problem solved? Having similar issues.
Old 07-31-2018, 02:00 PM
Yes I did. Two things that were tried...
I switched to Ethernet port 1 on the MTM. Which, I’m not sure if that actually fixed it.
Total restore of the system software. Took it back to whatever version is on the USB stick and the upgraded to the latest.
Been fine ever since.
Artist keeps disconnecting after a while HDXSound Artist Series 3 08-11-2017 11:02 AM
Mbox 3 pro crashing/disconnecting DoronFarhi FireWire & USB Audio Interfaces (Win) 11 10-03-2015 10:45 PM
S5MC disconnecting from PT Steven1145 System 5 5 08-19-2014 02:12 PM
Inputs Randomly Disconnecting m.chavie Pro Tools SE and Essential (Win) 0 02-04-2013 05:31 PM
Direct Connect - DISCONNECTING BUG saltminer Pro Tools TDM Systems (Mac) 16 01-18-2001 05:06 PM
