Weird problem with MIC being on when not recording
Hello I have an Apollo Twin MKII, 4K imac and Pro Tools 12. For some odd reason randomly my mic is on when I'm not recording. Pro tools can be closed and I can still hear my mic. Does anyone have any insight on what could fix this.
Thanks |
Re: Weird problem with MIC being on when not recording
Well clearly it's not Pro Tools... so what other software do you have that is accessing the Microphone? Start at Audio/MIDI setup... then UAD Console...
Look in the Apollo console s/w - your problem is there.
Yes what Musicman691 said. Turn rec off in the Console and see if that does it.
The OP simply needs to mute/cut that channel in Console. SUNNEDC, this is a feature of the Apollo system. The ability to simply pick up an instrument and hear it, or sing into a mic and hear it without having to mess around with your DAW. Check out this video, it's all explained here. https://www.youtube.com/watch?v=WTQyPTCAeGc |
And Sunnedc the Console software can do a lot more than just direct monitor and you will want to spend time working out how to insert plugins there, track dry and/or wet tracks, build different cue/monitoring mixes etc. via the Console. Even if you are not sure you will use it, it is worth learning what is possible.
Sent from my iPhone using Tapatalk |
Weird Midi recording behaviour | stevegalante | Pro Tools 12 | 7 | 05-11-2016 08:50 AM |
Weird ticking sounds in recording. | codyjtapp | Pro Tools 11 | 1 | 03-10-2016 03:11 PM |
Weird Recording Question | Bfearr | Windows | 5 | 12-13-2015 05:43 PM |
Weird digital distortion while recording | Musepro | FireWire & USB Audio Interfaces (Mac) | 9 | 09-18-2014 10:58 PM |
weird MIDI behaviour during recording | SoundReplay | Pro Tools TDM Systems (Mac) | 0 | 07-05-2006 02:18 PM |
