Noisy outputs on Profire 2626
Hi everyone, recently I've been having some problems with the outputs on my Profire 2626. Whenever I plug my guitar amp into the outputs of the profire (for reamping purposes), I get a bit of noise coming out of the amp. I know this isn't my guitar, pedal board or amp because those are all dead quiet when I play normally. Additionally, the noise level coming out of the amp is the same whether or not my volume pedal is on or off. So basically, it looks like this:
Guitar -> amp = quiet Guitar -> Pedals -> Amp = quiet Profire output -> pedals -> amp = noise Profire output -> amp = same noise It's not a 60 hz hum, it's more in the upper register (I can't say exactly where). Is this a ground loop? All help is appreciated! Paul |
Re: Noisy outputs on Profire 2626
Hi Paul, you should use a reamp box, if you don´t have one, you can use a direct box routing the other way around. Also, you should set the output in unity.
good luck! |
PT MP9 & ProFire 2626 | Rjones17 | Pro Tools M-Powered (Mac) | 0 | 12-04-2012 11:48 AM |
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) | tomv-k | Pro Tools M-Powered (Mac) | 5 | 03-09-2012 02:45 PM |
Profire 2626 Outputs | jaredryan | Pro Tools 9 | 1 | 08-20-2011 10:46 AM |
Can this be done with the profire 2626 | boabyd23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-03-2010 10:05 AM |
Profire 2626 Outputs grey in I/O setup | Trevoire520 | Pro Tools M-Powered (Win) | 7 | 07-08-2009 09:32 PM |
