#81
Re: HEAT (Harmonically enhanced Algorithm Technology)
THANKS for posts like this fasttraxx
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
#82
digging Heat here too !! very much...I wish it would work on instrument channels too though...Digi - is this something we'll see in a future upgrade ? when u have 20-30 tracks of VI's it would be kinda nice to hear them heated up
#83
As to whether it's fair or not, that's up for debate, as AFAIK most manufacturers don't offer hardware trade-ins. So the argument could be made that Avid is being more fair and considerate of the their customers than most companies that just leave you at the end of the line with no help at all. |
#84
So from what I am reading, no HEAT on instrument tracks or Auxes. Why would Digi, Oops I mean Avid, miss out on that?
...for system configuration info see my profile (Click on member name) |
#85
Hi, from the screen shot it looks like it's using 5 chips?
#86
I've checked closer and 60 mono tracks uses 2 accel chips or 4 non accel chips When i first checked on a large session it was using just over 1 accel chip for about 50 tracks Chris
#87
I only got 14 day demo. How can I get 30 day demo? Should I delete the 14 day demo first?
#88
I'll try to break it down for ya guys since I was wondering that myself.
So, on a mono track it takes up 14% on a stereo track it takes up 20% when you have 2 of them on at the same time, it takes up 26% Another note for you guys who are wondering this, When you move the Drive knob all the way to the left, you get about 5.5db of compression or more headroom if ya want to call it that. Moving it to the left means that you are using it as a tape machine. When you move the drive all the way to the right, you get about 6.1db of compression/more headroom. When you move it to the right, it's suppose to be a tube emulation, which I'm sure they mean mixing board emu. It does add a cool sound and I think used lightly, it could build up a nice mix. I was putting a Hip Hop Loop in it to get these numbers and I was using trim to add level to .01db so, I could hit it hard. To get the most out of it and see what it does. When you drive it hard, it seems to fold a little, break up or rather get too distorted. Again, if they just give you 4 half knobs, 1 for the tube sat, 1 for the tape sat, 1 for the dark tone and the last knob for the bright tone, they would really really have something. They would even have to change nothing as far as sound and keep what Dave did. Just break up the knobs as they are broken up but, 2 sounds on one knob doesn't give you the best options. Avid, think about it for a sec. Put the tape knob first as if it was coming to tape. Put the Tube knob second as if the tape was going to the board. Put the Dark or bright knob next. Better yet. Make it 3 knobs as I see no need to break up the tone knob as it is dark or bright. This makes more since and this is real world thinking, if you want to make this an Pro Tools Mixing Board Sound!!!! Marc
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies) YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc |
#89
As you ad more tracks the usage comes right down! 60 mono tracks @48k is using 2 accel chips (aprox 3% per track) or 4 non accel chips (6% per track).. Chris
#90
+1
Grateful for a heads-up on how to get the 30-day demo.. thanx! |
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
9.0.2 crashes when setting X-Form algorithm | A Chapman | macOS | 3 | 03-22-2011 08:38 AM |
Melodyne algorithm unhappiness thread | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-26-2009 02:28 PM |
Rhythmic algorithm | Steve MacMillan | Pro Tools TDM Systems (Mac) | 3 | 11-28-2007 10:44 AM |
positional scrubbing algorithm? | KingTor | Pro Tools TDM Systems (Mac) | 0 | 06-05-2000 01:04 PM |
