Pro Tools Closing
I am running Pro Tools 7.1 HD and every so often when I am running a pretty large session, Pro Tools will suddenly close out of no where. Usually it happens when I am focusing on a small portion of the song and stopping and starting very frequently. I have already run the tech support utility and reset the preferences. Any thoughts on what might be causing this and how to fix the problem?
Thanks -The Ripper |
Re: Pro Tools Closing
We're going to need more info - see the Help Us Help You thread for details on what we need to know...
System drive/users/your name/library/logs/crash reporter/pro tools... and see if there is a crash log for the time is quit. copy paste the crash log here!!
try opening your activity monitor in Utilities and see if you are running out of System memory.
Second, if it's crashing when you are doing micro editing, it sounds to me, with the information you provided, that your disc is not reacting fast enough to handle the work. It could be a myriad of things from there, but you could try around robin allocation by starting a new session and setting it to round robin disk allocation and then import the session data. Just two cents for now. |
error by closing pro tools 9 | harryheylen | Windows | 5 | 02-09-2012 12:37 PM |
pro-tools 8 keeps closing please help | zionsnoiz | Pro Tools M-Powered (Mac) | 2 | 03-08-2011 04:41 AM |
Pro Tools closing on me! | manicdown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-17-2007 11:40 PM |
pro tools app. crashes when closing session | Blake Henderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-27-2001 04:22 PM |
Finder crashes when closing Pro Tools | Stratman | Pro Tools TDM Systems (Mac) | 26 | 11-28-1999 11:31 PM |
