Ducking
question: i recently read an article about ducking (in my case, putting the kick drum through a compressor and hooking the bass signal through the sidechain.)
now i understand how to do this through my outboard compressor (dbx 266xl) but is it possible to do this using a compressor plug-in? if someone knows, please let me know. cory |
Re: Ducking
you need a compressor plug in which allows external keying. send your drums to a bus of your choice and then select the same bus on the plug in's external key pop up. not the kick drum should make the bass duck whenever the kick hits.
PT LE 7 & MBox Windows XP SP2 P4 3.0GHz CPU, Intel 865/PE/P Chipset 1GB RAM 2 X Seagate Barracuda 80GB HDD Novation Remote SL MIDI Controller |
Re: Ducking
Standard digirack copmpressor gate and limitter allow for external key signals...
set it up like this: -compressor on the bassguitar's track -send the basedrum to a bus (through one of the sends..., and make sure there are no other signals on that bus. -click on the key-button on the plugin to turn it on, and select the proper bus at "key-input" -now set the compressor until you are happy with the results In essence Equality 7-2521 said the same btw....
What's that? - That's the machine that goes "pling". Bastiaan |
Re: Ducking
Cavell Studios |
Re: Ducking
wow..i missed that one
Re: Ducking
Ducking | NativeLuv17 | Tips & Tricks | 3 | 10-27-2008 04:47 PM |
Ducking within the console | timcorder | VENUE Live Sound Systems | 1 | 06-21-2008 02:35 AM |
ducking advice | sbag | Tips & Tricks | 4 | 05-16-2008 03:00 PM |
Ducking | strizzack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-07-2005 05:01 AM |
Ducking? | neil_mcdermott | Tips & Tricks | 9 | 07-11-2003 11:53 AM |
