#21
Re: pan pot/knob missing from audio track
hey chucks, heres another picture of bus set up defaulted....
Pro Tools 2018.10 MacBook Pro late 2013, i7 2.8 GHz, 16gb, 500gb ssd macOS High Sierra 10.13.3 Native Instrument Komplete Audio 6 |
#22
You don't have the KA6 selected in PT. It looks like you're using the built in or aggregate. Post a picture of your Audio/MIDI setup screen - the Audio part.
PT 2023.12 DP 11.3 MOTU M4 HP Envy 8G i7 Quad Laptop Win11 PT 2023.12 DP 11.3 828es ADA8200 MTP-AV 2023 MB Air Sonoma VEP 7.x with various VIs on HP Z2 G4 Xeon Workstation Win11 |
#23
ive attached a pic, but I'm not sure if thats the audio/midi screen you spoke about, I hope so
p.s everything sounds good now, I'm not sure whats happened. do you think defaulting the bus set up did the trick ? ive also changed the headphones to a better pair, so I'm not sure if that may have helped.
#24
OK, this hs been covered earlier in the thread.
Launch PT Menu Setup --> Playback Engine, then select the KA6 as your Playback Engine Menu Setup --> I/O Setup, then Option-click the Default button, click OK Now when you start a new session your I/O should be correct. New Session, create a mono Audio track and a stereo Master Fader. They should default to the KA6 I/O 1 and 2 - no need to change them.
#25
hey ChuckS, in the I/O Setup, do I Option-click the Default button in each the output tab, input tab, bus tab and insert tab ?
I apologise for having to spoon feed me this stuff
#26
All this is called “defaulting the I/O”. And you can just select I/O paths and name them anything you want. The names have *no* meaning they are just convenience labels. The Pro Tools Reference Guide is worth a read to understand all this. |
#27
thanks very much...im gonna have to spend a weekend on this to get really familiar with it. ill certainly check out The Pro Tools Reference Guide you mentioned. Everything seems to be working now, I'm so grateful everyones help.
Everybody send me your IBAN numbers so I can sort you all out with a pint for giving up your time to me...and any knowledge I gather from here I'll make sure to pay it forward
#28
Just for future reference, option-clicking should change all the I/O tabs to their defaults so you don't have to do each one individually.
Missing regions in audio track + major automation loss | garnoil | Post - Surround - Video | 15 | 01-21-2010 10:13 AM |
Hybrid 1.5.2 - Missing Knob Legends | wcody | Virtual Instruments | 12 | 11-12-2008 12:52 PM |
Missing Audio track when I open a saved session? | Dj A-Ron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-11-2008 10:32 AM |
audio track missing pan control??? | davidp158 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-01-2002 03:02 PM |
missing audio at beginning of track! | guitates | Digidesign Hardware & Software | 3 | 01-23-2001 10:30 AM |
