Compression kills Clip Gain
I'm heavily compressing a track that has clip gain increased at the chorus. Because Clip Gain is pre-insert, the compressor is yanking the volume back down so it has no effect on output volume - it's just squashing.
Is there a way to do clip gain post insert without automation? I need complete fader control and don't want to mix thru Trim Plugins or Trim Automation. |
Re: Compression kills Clip Gain
For post insert you have volume automation and trim automation. So if you want to still be able to use your faders for mixing, make the adjustment in the trim automation section and leave the volume automation untouched. Or setup an aux, which you can use to control the fader for mixing, and write the volume automation on the track. Or automate the input control of your compressor. Or use a VCA-track. Timothy |
Your problem is exactly what I like about clip gain. I can make sure the audio is hitting the compressor at the same level all they way through. Then I use volume automation for dynamics.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Talk about totally missing the point of Clip Gain!
You could even things out with Clip Gain and then convert it to Volume Automation, then process with Inserts.
+1 You get a really smooth result with this
Adjusting Clip Gain On More Than One Clip | Blank Frank | macOS | 17 | 05-15-2015 06:34 PM |
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
Export Clip With Clip Gain | BobbyDazzler | Pro Tools 10 | 0 | 03-03-2013 03:06 PM |
Clip gain on clip groups: bug or feature? | idris | Post - Surround - Video | 6 | 01-02-2013 10:48 PM |
Clip gain?? | cocamycola89 | macOS | 3 | 10-23-2011 12:31 PM |
