Old 11-26-2012, 09:42 PM
CDIBarnes CDIBarnes is offline
Default No Timecode output from Protools I/O
We just purchased 3 HDX systems with new hardware and for some reason the LTC output has no output on any system. No TC at all. We have been on the phone with Avid support, but no luck. Are we missing some obscure setting? Dip switch? Anything you all can have us try? Thanks
Old 11-27-2012, 03:02 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Default Re: No Timecode output from Protools I/O
Is this on your Sync HD?
More info would help us get to the heart of the problem
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 11-27-2012, 03:30 AM
Drew Mazurek's Avatar
Command J
www.drewmazurek.com
Old 11-27-2012, 07:35 AM
Yes, brand new Sync HD. What 's the command J thing? Thanks
Old 11-27-2012, 12:06 PM
Craig F Craig F is offline
command J put Pro Tools online but that old way
do you have the LTC button clicked on in the Synchronisation section of the Transport
Thank you,
Craig
Old 11-27-2012, 04:15 PM
We figured this out. Remember, we are generating TC, not receiving. So Command J does not apply.
>In short, our installation, which requires long sync cables, are the
>issue. Apparently, the new cards do not send as beefy of a signal as
>the old systems. It is not an issue of software or old vs. new sync io's.
>Here's how we got to the bottom of this...
>This morning, Scott discovered that, for reasons no one can recall, the
>studio D sync cable ran through an ethernet-based extender while
>studios F and C did not. Yesterday, F and C didn't generate timecode,
>although they 'saw' the sync i/o, whereas studio D didn't even see the sync i/o.
>This morning, Scott cycled power on this extender, and voila' - Studio
>D sees the sync i/o, generates timecode, etc just fine. (our session
>was saved. Thanks Scott!)
>Next, we used this boosted cable set up from the studio D rig on the
>studio F hardware, and it all works perfectly as well. So we now need
>to buy two new extenders.
>The item to add to the knowledge base is something like: Long sync i/o
>cable runs which used to work on earlier systems may not work on the
>new ASX card systems without running though a signal booster.
Old 11-27-2012, 06:45 PM
PITA but good to know, thanks
Thank you,
Craig
Old 11-28-2012, 05:27 AM
I thought it used to be that way.
www.drewmazurek.com
Old 11-28-2012, 12:09 PM
it was but in 9 (or was it 8) this was changed so LTC generation can happen w/o putting PT online
Thank you,
Craig
Old 11-28-2012, 12:28 PM
Shows how long it's been since I did that!!!
www.drewmazurek.com
Generating smpte for output to camera timecode slate Optofonik Pro Tools 11 4 12-17-2013 05:39 AM
Need someone to output to D88 5.1 M&E timecode etc Mark 66 Post - Surround - Video 6 01-14-2007 08:35 AM
Output to tape with Timecode with LE? WannabeSQ Post - Surround - Video 12 05-22-2006 06:13 AM
USD SMPTE timecode Output? pnoise Pro Tools TDM Systems (Mac) 8 03-12-2001 09:14 AM
Timecode (LTC) output on USD DannyVanSpreuwel Tips & Tricks 0 05-12-2000 10:01 AM
