MBox 2 share drivers with other apps?
I'm sure I recall there was a way to allow an MBox 2 to share its drivers with other applications, but I can't find where to enable this. Ideally I want to use an existing MBox 2 to record some basic 2 track files into Cool Edit Pro which I have installed on a portable hard drive. I'd rather not have to install PT on this drive if I can avoid it, since I won't be multitracking at all.
Re: MBox 2 share drivers with other apps?
You would need an ASIO compatible application and the stand-alone ASIO driver if you don't intend to install Pro Tools.
Cool Edit was never ASIO compatible ... so you're out of luck with that. Even it's successor Audition wasn't made ASIO compliant until version 2 IIRC. |
Yes I recall it used to share OK with Sonar which must be because of Sonar's ASIO drivers. But will this just happen automatically? I seem to remember I had to do something to allow Sonar to "see" the MBox
In Sonar you must make sure Sonar is seeing the specific Digidesign ASIO driver and not a stock driver. Options > Audio > Audio Options > General tab. Good luck- |
Audio apps take long time to launch after installing mbox drivers | steelgrooves | FireWire & USB Audio Interfaces (Mac) | 1 | 12-26-2013 12:27 AM |
Share your Pro Tools regions with other apps... | Rail Jon Rogut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 10-08-2004 08:11 PM |
share Mbox/PT-LE with 2 computers? | birddogman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-03-2003 10:29 AM |
MBox with other apps | Polaris20 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-17-2002 02:19 PM |
Mbox users, could you share your tips ? | ISedlacek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-07-2002 10:37 PM |
