Wavefile slicing
Hello,
I have a single stereo wavefile that contains multiple songs that I would like to divide up and save each song as a separate session. How can I accomplish this? My second question is, suppose I have added additional tracks to the songs mentioned above, and want to then save the completed song as a separate session; how can I do it so that the tracks will still be in sync when I recall the session? Thank You |
Re: Wavefile slicing
This is what I would do. I would save a copy of the session that contains the long file with a different name for every song you want to save. Then I would just cut out whatever part of the file I didn't need for each of those sessions saved. |
What's up mix , God bless ya man. You know, I have tried your suggestion in the past and it works fine, but I'm just concered this time about all the hard drive space this particular file will take up if I copy it seven or eight times. What I'm wondering is if it's possible to divide the wave up in a permanant (destructive) way to save space.
Each region refers to the same audio file, the regions are only visual representations of the audio being played, but they'll still come from the same source file.
You can have multiple sessions in the same session folder, so that they can share the same audio folder, that way each region in each session is pulling from only the ONE file. Create several copies of the session IN THE SAME SESSION FOLDER, and name them in sequence referring to the songs. Then open each one and select the length of the song that you want to keep for that particular session and trim the ends off. (crtl+T) save. Do that for each one, save them, and abra cadabra, you have X amount of sessions with different regions streaming from the same file. Hope that helps, I haven't been on pro tools for a while, been fixing my computer.
Joe Fitz Producer / Engineer |
Slicing/Separating clips How To? | ircswh | Windows | 1 | 05-24-2012 07:00 AM |
Video lagging when scrubbing on wavefile. | fakeknot | Post - Surround - Video | 1 | 04-06-2011 05:13 AM |
Wavefile Syncronization | SlipKid | Pro Tools M-Powered (Win) | 3 | 12-31-2006 11:37 PM |
Beat Slicing vs. Time Stretching | danika | Pro Tools M-Powered (Win) | 1 | 10-04-2005 12:40 PM |
losing wavefile display | oreo1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-14-2001 07:06 PM |
