LE Quality compared to HD/TDM Quality
I realize the benefits of HD when tracking outboard instruments and vocalists but when using 100% software plugin instruments and effects can anyone tell if a track is rendered in HD vs. LE? Assuming the same exact plugins are used on both systems.
Re: LE Quality compared to HD/TDM Quality
No, not really. Since the audio quality (usually) is better when using TDM systems, the plug-ins will just naturally sound better applied to higher quality audio.
[TheLP] |
I don't know that the audio file itself would be better in TDM than in LE, but the mixer in TDM is of a higher resolution so, technically, a TDM mix has the potential to sound better. I've done a test where I mixed a bunch of audio tracks via a TDM mixer, then imported the same tracks to LE (without any plugins or level adjustments) and the TDM output was indeed a little better. Wider, deeper, more defined. It wasn't drastic, but noticeable.
And for the record, I don't believe there's a difference between the TDM and LE plugins themselves. Someone else feel free to chime in, but it's my understanding that the audio processing code itself is typically the same. |
Delay compensation!!!!!!!!
Your phase across the board will be smeared by plugin-induced latency. TDM systems compensate for this and allow you to run your entire session without killing the horsepower on your host computer. |
You can always improve the outputquality of a LE System with a pro wordclock and D/A drastically and still have only 30% of the expense of HD system. so MIXBus issues are TDM with 48Bit fixed vs LE with 32bit float. both have their pros and cons. There was a pretty extensive thread in the TDM forum once and various other threads concerning the issue but I can´t find them at the moment. and as always: the most important link in the chain is the engineer, not the tools. regs
last: PT11.3.1 |
better quality power cable = better quality sound? | dbvoyager | General Discussion | 22 | 04-15-2012 06:08 PM |
LE quality vs HD quality | spaceman | Pro Tools TDM Systems (Mac) | 26 | 01-22-2004 05:07 AM |
Hip-hop mix quality? | jazzy655 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-02-2003 10:04 PM |
Mix Down Quality | Jose A Lugo | Tips & Tricks | 17 | 08-03-2002 12:46 AM |
mp3 quality??? | anders | Tips & Tricks | 7 | 10-23-2001 01:51 AM |
