Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
  #21
Old 05-13-2016, 10:17 PM
propower propower is offline
Default Re: Apogee introduces new Ensemble Thunderbolt
I just got one of these today and am putting it through its paces (in my world that is measuring RTL and performance at 96kHz with lowest buffers).
It really is 1.1ms at 96kHz/32buffer in Logic. Actually runs decent there with 3 tracks in record (will test more later). At 64 buffer in Logic it comes in at 1.8ms - same as HDN at 96k/64. But when I switch over to ProTools at 96kHz/64buffer I get 2.44ms latency. I tested it with a new session and one track - no plugins - still the same.
All I can figure is that AVID has made the lowest path in and out of Pro Tools less efficient for 3rd parties than it gets with its own TB box. Surprising - and somewhat depressing for a low latency freak like myself...
-------------------- update 9/21/16
THE reason that I got the 2.44ms value is because I had the box checked in Playback engine setup for "Ignore errors during PB and Record". This adds a safety buffer in PT. Take it out and RTL is 1.78ms for 96kHz 64 buffer and Apogee Ensemble. This is very close but not exactly the AVID Omni value since the A/D D.A times for Ensemble and Omni are slightly different. At 44.1kHz the Ensemble is significantly faster A/D D/A than the Omni - hence RTL is markedly lower.
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
  #22
Old 05-14-2016, 10:14 AM
gthm's Avatar
gthm gthm is offline
Originally Posted by moleif View Post
Bought mine Nov/2015. Absolutely love it! Also, using it as a master clock. Everything sounds better and can autoswitch sample rates on the fly.
Hey!
What kind of Mac do you use with your Ensemble TB? What else do you sync to its clock? Curious!
Pro Tools 2024.3
macOS 14.4
iMac (24-inch, M1, 2021)
(16GB RAM, 1TB SSD internal)
Samsung T7 x a few
Samsung 980 Pro x 2 (in Acasis TB/USB 4 enclosures)
Apogee Ensemble Thunderbolt (my hero)
  #23
Old 09-21-2016, 01:54 PM
jacko's Avatar
jacko jacko is offline
I just did a test at 44.1KHz of Ensemble Thunderbolt vs HD Native / HD Omni:
HD Omni:
32: 148 (3.35ms)
64: 212 (4.8ms)
Apogee Ensemble Thunderbolt:
32: 126 (2.86ms)
64: 190 (4.3ms)
(corrected after propower's post below)
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
  #24
Old 09-21-2016, 02:27 PM
I don't agree with your measurements for the Ensemble - but the OMNI look like I remember. I also discovered a flaw in the original test I did that I corrected in other threads but not here. One must be careful NOT to check the PT box in Playback Engine Setup that says "Ignore Errors During PB and Record" - this adds extra RTL. (see my post edit above - Apogee TB is faster than OMNI at 44.1kHz, at 96kHz they are about the same)...
When this (and all boxes in Setup - Playback Engine are unchecked) with Apogee Ensemble Thunderbolt you get:
96kHz 64 buffer RTL = 1.78ms
44.1kHz 32 Buffer RTL = 2.87ms
In Logic ProX you get exactly the same but you also get a useable 1.1ms at 96kHz 32 buffer with some restrictions on plugins...
  #25
Old 09-21-2016, 02:33 PM
jacko's Avatar
That was enabled on my friend's system where I did the measurement.
I will redo the test. Thanks!
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #26
Old 09-22-2016, 02:13 AM
jacko's Avatar
@propower I corrected the values!
Amazing, Apogee Ensemble Thunderbolt has actually lower latency than HD Native.
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Apogee introduces Quartet interface nst7 Pro Tools 10 5 09-05-2012 08:44 AM
PT 9.0.6 HD TDM with Apogee Ensemble Paul B. Pro Tools 9 1 04-01-2012 04:59 AM
DIGI 003 + Apogee Ensemble + Apogee Big Ben = World Clock marcioguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-11-2011 02:24 PM
Apogee Ensemble mickeymassacre Pro Tools 9 0 11-13-2010 09:24 PM
Apogee ensemble for 8 more A-D ins on OO1 PCI? voltech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2007 09:16 PM
