Hearing vocals in headphones as i am recording it.
Hello,
How do I hear my vocals in both sides of my headphones while I am recording it. I have Protools 8le and MBOX PRO. THANKS MUCH. |
Re: Hearing vocals in headphones as i am recording it.
You should be recording to a Mono track.
Just make sure that track is panned to centre of ur 2 channel output
--- I am here: http://maps.google.com/maps?ll=-36.925465,174.696393 |
To hear my voice in my headphones while recording vocals I need to switch my headphone to one of the outs on the back of my MBOX PRO. I will not hear my voice in the headphones with them plugged into the normal phone jack in the front of the MBOX while recording the vocals. Any way to hear them with them plugged into the front jack on the MBOX while recording vocals?
Thanks. |
Not sure if im misunderstanding your setup but have you tried pressing the "mono" button on the mbox?
As I said above, it sounds like you are a recording a mono source (mic) to a stereo track. Make sure you are recording to a mono track.
Pressing the mono button on the mbox should sort the headphone issue.... also yeh record to a mono track if its a mono source but im not sure that will alter the monitoring issue. |
It is unlikely, but possible that the routing is incorrect. Open the mbox3 pro control & look at what is routed to the headphone output.
Main Workstation: Pro Tools 2023.12.1, Windows 11, HP Z4 Xeon 8 core W2145, 64 GB DDR4, Omni, Artist Mix, Sync X, Eleven R(2 of them), UAD 2 PCIe card |
In Pro Tools>Track> toggle between Auto input monitoring and Input only monitoring.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
hearing vocals in headphones | mgsr70 | macOS | 16 | 12-09-2012 11:16 PM |
Hearing effects on vocals while recording. | cnorah74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-04-2008 06:27 PM |
Hearing effects on vocals while recording. | cnorah74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-03-2008 05:37 PM |
Hearing reverb while recording vocals | Semantick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-22-2004 06:55 AM |
keeping recording levels, but not hearing through headphones | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-02-2002 10:31 AM |
