DAE Could Not Be Found
When I try to start PT LE on my windows XP Home.. I get "DAE Could Not Be Found" then a box that says ...Microsoft Visual C++ Runtime Library......
c:\program files\digidesign\ProToolsLE.exe ...the application has requested the run time to terminate in an unusual way. please contact applicants support team. I also went to my add/remove to try and uninstall and then reinstall PT..but for some reason that (the add/remove) wouldn't open. All the other things open but that one. (display, user accounts.. etc) Any help on this? Thanks, Jason |
Re: DAE Could Not Be Found
reinstall windows WX and try again. Sounds like windows itself is corrupt. Virus?
What's that? - That's the machine that goes "pling". Bastiaan |
You might try using something like RegCleaner to remove all Digidesign and Pace components, then try to reinstall.
What version of Pro Tools are you running? What are your system specs? You can download RegCleaner here: RegCleaner After installing, launch RegCleaner and click on the Software tab. Select all Digidesign/Pace components and click 'Remove Selected'.Do the same for the 'Uninstall Menu' tab, then quit and restart. |
Thank you for your post. I'm using windows XP home..Pent4 3.0Ghz...512 Ram ProTools 5.3.1...Digi 001. Looking forward to my 6.3 upgrade but I have to solve existing problem first.
Thank you Jason |
c24 not being found | awakenedgroup | ICON & C|24 | 1 | 02-10-2013 04:13 PM |
Bug I found in 2.6 | Xill | Artist Series | 11 | 07-30-2011 10:25 PM |
003 not found - PT 7.4, OSX 10.4.11 | Novemberlima Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-07-2008 08:47 AM |
"DAE Not Found" | barefoot1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-15-2007 03:22 PM |
"DAE could not be found" | barefoot1 | Pro Tools TDM Systems (Mac) | 1 | 02-12-2007 10:36 AM |
