No sound available to Windows when Pro Tools LE is running?
Hi there,
I've got a problem where I can't use my MBox for audio playback outside of Pro Tools LE when Pro Tools is running. Can any please help? This is my first post so hopefully my system specs will appear somewhere. EDIT: They do but not in this post! Here they are again. ------------------ Pro Tools Information ------------------ Pro Tools LE 8.0.4 M-Box 2 ------------------ System Information ------------------ Time of this report: 8/20/2010, 16:37:24 Machine name: VAIO Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621) Language: English (Regional Setting: English) System Manufacturer: Sony Corporation System Model: VPCF11C5E BIOS: BIOS Date: 09/23/09 11:58:43 Ver: 08.00.10 Processor: Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz (4 CPUs), ~2.4GHz Memory: 4096MB RAM Available OS Memory: 4014MB RAM Page File: 2341MB used, 5684MB available Windows Dir: C:\Windows DirectX Version: DirectX 11 DX Setup Parameters: Not found User DPI Setting: Using System DPI System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled DxDiag Version: 6.01.7600.16385 32bit Unicode |
Re: No sound available to Windows when Pro Tools LE is running?
Does it work when Pro Tools isn't running?
What programs and content specifically? What sample rate are you using when Pro Tools is open? (I'm betting something other than 44.1, but I could be wrong)
Yes it works when Pro Tools isn't running.
The sample rate is 48Khz not 44.1Khz. |
And that is why it won't work. Pro Tools has the hardware locked at 48, and you are trying to playback in the other program at 44.1.
Try opening or creating a Pro Tools session at 44.1 and see if that solves your problem.
How do I change the sample rate?
Me = Pro Tools Newbie. |
You can only "change" the sample rate when creating a new session, so...
Create a new session and select 44.1 as the sample rate.
Odd 44.1KHz is the only option when starting a new session now. Blank Session must have defaulted to 48Khz.
All is working great again. Thank you for your help. |
Pro Tools 10 & ASIO4ALL on a Mac running Windows | aj88keys | Pro Tools 10 | 1 | 01-09-2012 01:39 AM |
Running Pro Tools Le/ M-Powered in compatibility mode using windows XP service pack 2 | fuddbeer | Pro Tools M-Powered (Win) | 2 | 11-06-2010 11:37 AM |
Pro tools on an intel mac running windows? | MagicG | Pro Tools TDM Systems (Win) | 1 | 06-22-2008 10:59 AM |
Pro tools HD on an intel mac running windows XP? | MagicG | Pro Tools TDM Systems (Mac) | 0 | 06-22-2008 03:26 AM |
Running Pro Tools on Windows in an Apple? | FutureHope | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-15-2006 06:17 PM |
