Embed audio into the video stream
Hi all,
I'm working with an AJA IO box as my output for video with Pro Tools. I'm wondering, is there a way to embed my audio mix into the SDI or HDMI stream coming out of my AJA IO4K box when monitoring video output? |
Re: Embed audio into the video stream
You can get an inline embedder to do this. Not cheap though.
~Will |
We have been using the Stellar Labs HDMI 7.1 Audio Inserter (Model 33-11680) for a few years now without any problems. We bought ours from MCM Electronics. It looks like it is going for $39.99 right now.
Cheers, Jonathan Jost Digital Audio Post, Inc. 1217 16th Avenue South Nashville, TN 37214 615-327-4012 www.digitalaudiopost.com |
Jonathan,
I noticed on the box that it only does TOSLINK audio format: LPCM 2CH, Dolby Digital 2~5.1, DTS 2~5.1 But the HDMI does: HDMI audio format: LPCM 2/5.1/7.1, Dolby Digital, DTS, Dolby Digital Plus, Dolby TrueHD and DTS-HD Master Audio So basically, if you are coming out of an Avid Omni using the toslink connector and going into the toslink IN of the box you can only use a PCM 2CH signal...you can't do a discrete 5.1 PCM or 7.1 PCM signal. You'd have to use a dolby digital encoder for surround right? |
black magic have a cheap one that works great for SDI
https://www.bhphotovideo.com/c/produ...ter_audio.html
Matt Perrott Sound Designer and Engineer Sydney, Australia |
Nathan W.
I think you are correct. It looks like you can't send more than two channels discretely over the Toslink, but you would be able to send an encoded multichannel bitstream. Truthfully, we have only really used the 3.5mm input to send our stereo mix to the television for alternate monitoring.
mbox 2 cant stream audio from the web? | deskman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 09-03-2008 05:07 PM |
MBox stream audio ripping | diggs1000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-11-2007 10:27 AM |
Audio stream over LAN? | GeneOuse | General Discussion | 0 | 04-03-2007 01:19 PM |
i cant stream audio off my external drive HELP | monkeyboy49 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-14-2006 05:09 AM |
Can ProTools HD set to work with Direct Stream Digital Audio | scoobdaproduca | Pro Tools TDM Systems (Mac) | 1 | 07-10-2002 02:04 PM |
