Re: App to create Bwav Poly files?
If you're apt in producing your own batch files, the Interlx commandline tool of the MCTool package (free as in beer and freedom) could be of help. There's an XP and OSX version available.
The commandline is Interlx output.wav input1.wav input2.wav input3.wav input4.wav The files seem to be completly legal multichannel WAVs, though without BWAV data I presume. Get the tools here : http://people.bath.ac.uk/masrwd/mctools.html
"My ego comes pre-shrunk" - Randy Thom |
It works. I do it all the time to archive multichannel ambiences as one poly BWAV. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
I don't want to dwell on symantics, but I was refering to Froyo's post where he stated just dragging onto a 7.1 track and Export and you're done. I then stated "renaming with 7.1 names is the only way to do it." Renaming isn't an option for me because of the number of files AND I wouldn't have a way to re-embedd my metadata associated with the original files (since the names wouldn't be match).
Tim Reisig Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram) |
oops, I edited my posting with another hint while you replied. Check my posting before this one to see if that helps. BTW: You could re-embed your metadata with soundminer. In fact you could do all the exporting in soundminer BUT again the suffixes have to match the 7.1-convention.
Soundminer als offers a nifty little app called metaedit that could help batch-re-embedding the metadata. Sorry, now I´ve run out of ideas... frank.
I understand what Tim R. is referring to and, no, PT does not provide any support for Poly Wav files. Some responders are hung up in the surround implications, mentioning 5.1 and 7.1 formats. This is not at all what he is talking about. Think of them more as 'file groups', which 'stick' together when editing, importing and exporting, etc; and have a metadata chunk that pertains to them as a group. Pro Tools seems oblivious to this essential workflow of film and location production.
As an example, consider two channels of dialog, a stereo ambience mic and a music cue; all generated simultaneously on the set. Many field recorders are capable of tagging this six channel recording as a single block, and the technical term is Poly Wav. The special metadata needed to describe this block of files and keep them together in recorders that support this format is in IXML. I can think of numerous applications for this in my record production work and would welcome it eagerly!
Peter Yianilos Artisan Mobile Recorders |
#17
Craig F. Would you like to substantiate that statement? I see no evidence or mention AT ALL of this after reading latest PT10 ug.
#18
page 6: Support for Interleaved Audio Files
http://akmedia.digidesign.com/suppor...409.pdf#page=9
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
#19
Craig. Interleaved files have nothing to do with Poly WAV format.
Completely apples and oranges.
#20
then why do my 5.1 SFX files from Blastwave that are poly wave work just fine and why can I make 5.1 SFX files form mono files?
poly wav files and PT 9 | allegrarc | macOS | 0 | 09-05-2013 06:31 AM |
10 and poly files from field recorders | Craig F | Post - Surround - Video | 2 | 10-21-2011 06:56 PM |
Importing poly wav files in PT 8 | fonograf | Post - Surround - Video | 8 | 04-06-2011 10:01 AM |
poly / mono bwav meta data problem | markuse | Post - Surround - Video | 2 | 03-24-2011 06:17 AM |
Poly Bwav, SM transfer problems | Reckless Erik | Post - Surround - Video | 19 | 10-14-2009 09:35 AM |
