Old 04-08-2011, 04:39 AM
triplex triplex is offline
Default Converting session using 3d sample rate converters. Possible?
Hello,
Does anyone has experience with downgrading Pro Tools sessions sample rate using 3d software converters (Izotope SRC for example)?
I'm looking for an easiest solution.
Thanks.
PT 12.8.0
Mac OS X 10.9.5
MacPro2,1 Quad-Core Intel Xeon
16GB RAM
Old 04-08-2011, 09:16 AM
Default Re: Converting session using 3d sample rate converters. Possible?
Originally Posted by triplex View Post
Hello,
Does anyone has experience with downgrading Pro Tools sessions sample rate using 3d software converters (Izotope SRC for example)? ...
I think the best you could do would be to convert all the audio from the session (the contents of your Audio Files folder) into *another* folder using a batch converter utility such as Audiofile Engineering's Sample Manager (which uses the Izotope SRC) or Saracon, then in ProTools do a "Save Session Copy In..." and change the sample rate to the desired rate; ProTools will insist on converting all the audio. Then throw out the newly ProTools-created audio, and when you open the new session, relink using only file names (not unique file ids) to the audio you created in step one. You'll have to be sure your audio files all have unique names and are in a single folder before starting this process. Fairly awkward, but I imagine you could get reasonably fast at it if need be.
Hope that helps,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Converting Sample Rate [email protected] Windows 3 12-16-2012 05:18 PM
Converting files sample rate Mack Truck Pro Tools 10 1 05-31-2012 10:25 AM
best method for converting session to higher sample rate CV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-14-2009 06:55 AM
Converting Sample Rate for 24>23.976 pull-down anders Post - Surround - Video 1 04-29-2006 05:10 PM
Converting Sample Rate /Dithering ukoomrann Pro Tools TDM Systems (Mac) 3 08-01-2005 07:07 AM
