Anyone running multiple hard drives?
Im running a 60g solid state drive that contains my operating system (windows 7) and a 500g hard disk drive that contains everything else (protools, eleven rack, plugins etc.)
My problems is that ever since I made the splits in hard drives my protools seems laggy and when I have my click track counting off for recording it will not start recording my track till 2 beats past the count off, and also pro tools does not see my eleven rack (my computer still recognizes the eleven rack). but it will record my 11r tone and even if my track is not record enabled it still plays the 11r tone which leads me to assume that pro tools is reading it as a audio in (i think). so when i do enable the track for recording it has a double layer of guitar tone. Any thoughts out there in duck land about this issue? My best thought is to get a bigger solid state drive and run both my o.s and protools. Any one else ever have this issue? |
Re: Anyone running multiple hard drives?
I typically reserve one drive exclusively for recording. I have in the past put VI's on their own drive but I'm using an iMac now and use system drive with PT and VI's installed, and a usb3 drive for recording. Everything rocks along just fine.
Current system: Pro Tools Studio annual Windows 10 Pro MSI home build 11th Gen Intel i7-11700K @ 3.60GHz 32g RAM, 6Tb SSD AVID Dock w/Android 10" Tablet IK Multimedia AXE I/O Behringer U-Phoria UMC1820 USB Audio Interface Bakerplace.net A place for Audio/Video Post Production. |
OS and app on dedicated drive and a separate drive dedicated to audio.
Pro Tools itself should be installed on the C: drive. Sessions need to be on a separate drive. If you use lots of sample-based VI's, the samples are best installed to a 3rd drive. If you only have 2, then install the samples on the C: drive. In all cases, the recording drive should do nothing else but record audio.
Yes, and answered wrong
Avid recommendation is to have OS and PT on a dedicated drive, and audio session(s) on another drive(s). Consolidating everything on single massive SSD is against Avid supported systems paper. Wherever your system is, it is perfectly fine. What you need to think about is your audio: 1) always store your session on a dedicated audio drive. ALWAYS! 2) if you use VI's or samplers that need to stream lots of audio, put those on their own dedicated drives. if you have lots of streaming, you may need more drives. 3) if your session is very large, you will probably need more drives. use round-robin allocation to make it easier to split files between drives. that said; your track count needs to be in high tens or even some hundreds before you should feel the need.
Actually he has the right idea. Pro Tools and the OS should always reside on the same drive. Having Pro Tools installed on a drive other than the OS drive is asking for problems. Considering plug-ins, 60GB SSD will not usually do for this, he will need to go bigger.
Of course audio should always reside on a separate approved drive, and samples on another. Back up drives are another necessity both for the system and also for the audio (sessions). I use 5 internal drives in my systems to accommodate these needs.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
This is the statement to which I am referring.
Now that makes sense Tom
Multiple Hard drives | DarthFader93 | Tips & Tricks | 3 | 10-27-2013 10:24 AM |
Running PT 9 and 11 on a separate hard drives | keithl | Pro Tools 11 | 3 | 06-27-2013 04:28 PM |
Multiple Hard Drives | wearetheniceguys.com | Windows | 4 | 05-02-2013 02:55 AM |
running different hard drives? | Death Metal Jim | Windows | 7 | 03-05-2011 08:54 PM |
How do you set the jumpers for running two hard drives | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-23-2003 07:27 PM |
