Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 01-24-2017, 08:22 AM
yop22 yop22 is offline
Default Softkeys problem with stacking commands
I'm trying to program a simple softkey to trim a clip and then create a fade but it doesn't work...
The sequence is:
- EUCON -> Trim Clip Start Back
- Key down arrow (to put the cursor at the beginning of the clip)
- Key NumPad + (to move the cursor by 1 frame)
- Key Numpad + (to move it again by one more frame)
- Key d (to create a fade to start)
All key command work but the EUCON one is skipped.
The only way to have it work is to assign the EUCON command by itself to another softkey.
Any idea ?
Win 7 pro 64, X99-UD4, i7 5820k@3.3GHz, 32GB RAM.
Pro Tools HD native 12.8.0, S3
Old 01-24-2017, 05:42 PM
ha2dorff ha2dorff is offline
Default Re: Softkeys problem with stacking commands
Have you tried to add a pause after the Eucon command?
Old 01-24-2017, 10:31 PM
I also thought that could help but I haven't found a way to do it. Is it possible ?
Envoyé de mon SM-G930F en utilisant Tapatalk
Old 01-25-2017, 12:30 AM
Mark Ziebarth Mark Ziebarth is offline
I tried something similar a few months ago.I think it is impossible to combine normal key commands with EuCon commands in one sequence.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2019, Euphonix MC Control
Old 01-25-2017, 10:40 AM
That seems a bit weird because the sofkey editor doesn't prevent one from combining them, like it does when trying to add more than one Eucon command.
Could it be a Wi-Fi speed issue ?
Old 01-28-2017, 10:23 PM
In my case I wanted to create a sequence for a new playlist. It's two steps: The "New Playlist" command and the "Ok" (Return-keystroke). Combining the EuCon command for "New Playlist" with the Return-key didn't work. With the key command for "New Playlist" it works.
Old 01-28-2017, 10:24 PM
It's not Wi-Fi related in my case because the Artist Control has a wired connection.
Stacking EUCON commands in SoftKeys StonehengeX Avid S6 5 09-28-2016 10:40 PM
vocal stacking hmsbass Tips & Tricks 5 10-24-2013 11:26 AM
Figured out problem with Key Commands on win. djmichaelwenz Artist Series 1 10-13-2012 01:08 AM
Problem with key commands ZackWithAMac macOS 6 07-26-2012 01:06 PM
stacking vocals toofly4asoundguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-01-2005 01:55 PM
