Old 01-12-2012, 11:19 AM
JC925602 JC925602 is offline
Default mBox pro or ProFire 26/26
I bought an mBox Pro and it was defective (noise at -65 on every output).
I returned it and the second unit had the same problem. Now they offer me a ProFire 26/26. Should I take it or get a refund and wait to find a mBoxPro that is OK?
It's for my home system; I do post work for TV and I choose the mBoxPro so I can install a surround system to be able to work at home from time to time.
Jean-Charles
Old 01-12-2012, 11:27 AM
weezul weezul is offline
Default Re: mBox pro or ProFire 26/26
If the firewire connection is being stable, I would take it. But only if you're going to use all the extra I/o. You will lose Low Latency Monitoring in Pro Tools if you take this option, but working on post that is probably not a major concern.
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 01-12-2012, 12:28 PM
nst7 nst7 is offline
The 2626 is a much older unit, and there's no telling whether it will be supported for very much longer, especially past PT10. Whereas the new Mbox Pro is a newer product that should be supported for at least several years to come. Also, I don't know if the 2626 has monitor control for surround, whereas the Mbox Pro does. And the Mbox Pro sounds very good, if you get a properly working version.
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) tomv-k Pro Tools M-Powered (Mac) 5 03-09-2012 02:45 PM
should I Change my Mbox 2 pro for Profire 610??? matias4000 Pro Tools 9 5 02-09-2012 09:01 PM
The New Mbox 3 or M Audio ProFire 2626 envO General Discussion 1 01-02-2011 08:34 PM
MBox 3 Pro, 003, or Profire 2626 Jwald 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-28-2010 01:59 AM
Profire 2626 & Mbox 2 run together? rockya1999 Pro Tools M-Powered (Mac) 2 11-22-2009 01:45 AM
