#21
Re: Recording levels? -18dbs
Darryl, you know far more about this than I do, so if you could help me understand this better, I would appreciate it. With my 002 Rack, the manual said that 0 on my meters in Pro Tools was -14 dBFS. Based on that, I thought that if the meter read a peak of -6, that would mean the peak was at -20 dBFS and set my pre's gain accordingly. Is that incorrect? As far as I know, with my Pro Tools vanilla, I am unable to set any meter offset in Preferences.
Thanks,
#22
"All Digi 002 audio inputs and outputs are set for 14 dB of headroom below 0 dB, or full code. This means at the nominal reference input level (+4 dBu or –10 dBV) you can have up to 14 dB of headroom before input or output clipping occurs." That is as statement about the *analog* design of the 002. dBu and dbV are all analog side signal level measurement. This does *not* say "0 on my meters in Pro Tools was -14 dBFS". dbFS anything is not mentioned here or relevant. Pro Tools classic meters are digital, they display dbFS, or as the reference guide used to (may still?) say. They indicate the (digital) levels going to/coming from disk. If you drive an input up to 0dbFS it damn well will start to digitally clip (go drive say a mic input on your 002 from a signal generator on an output and prove it to yourself). If you want say 16dB of headroom at the converter for transients then you just track at -16dbFS. You don't need to worry about the analog domain, at least not to the first order, you are worried about overhead at the converter, and the converter digital output tells you all you need to know. In more complex setups what you do as far as analog side behavior etc. gain or attenuator settings or analog console settings for analog signal reasons should be judged by you actually listening to the signals and what sounds best. Last edited by Darryl Ramm; 05-23-2016 at 05:23 AM. |
#23
#24
I remember sending music files to Pro Tools from a Digital Betacam tape. The DB tape was recorded to the broadcast standard of -18 dBFS. The PT mixer raised everything to up to get close to "0" and then send the mixed file back to me and the DigiBeta. It was now too high, almost hitting clipping.
A sound recorded at -20 will sound the same at -50. It will just have a little more noise that you will not hear, especially if you dither.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
#25
This isn't true of anything but simple gain changes and the very simplest plug-ins. All analog modeled plug-ins have a sweet spot exactly the same as all analog gear has. Otherwise it isn't an accurate model! No plug-in developer assumes their plug-in needs to be accurate when sent signals above 0dBFS. It is operating outside of the design and may or may not be a problem.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#26
Again, this all comes down to numbers. If your AD converter has a dynamic range of 124dB (a good one!) then you have 20dB headroom and you gain NOTHING if you record any hotter than that (-20dBFS). So better be on the safe side. And then again... there are not so many situations where you really need +120dB dynamic range. Your dialog or lead vocal or acoustic guitar or whatever has way lower dynamic range to capture. You need to think of gunshots or explosions or jet flying over your head under 300 feet if you would really be concerned about the NOISE FLOOR which is analog concept and usually totally nonsense in digital domain. So to repeat myself, find that monitoring volume knob and turn it up!
#27
--- I'm not sure how many threads these never ending questions about tracking input levels takes for everybody here to try to help with from every possible angle but what I think new folks need to do here.... Have a read about some basic stuff on conversion, understand conversion bit depth and dB dynamic range, dB gain, dbFS, dbV, dBu, Vrms analog signal levels. (Maybe grab a voltmeter or scope and a signal gen plugin and confirm you understand this stuff in practice). Get decent monitors/headphones/amps, understand how to get stuff turned up loud with the a volume knob not the input gain. (Seems a perennial issue in posts on DUC). Start by not tracking too hot to avoid clipping. Understand dbFS and what the meters are telling you. Watch stuff in dbFS. Track at -16dBFS?, -20dBFS? I don't know, who really cares., but not normally -3 dBFS or -6 dBFS. Listen carefully with your ears to analog front-ends, and what is happening with plugins. And yes OK realize that plugins as well as analog electronics have sweet spots. If in doubt do some A/B tests for yourself. if you prefer something, do that. |
#28
That is only true if you apply +30dB of gain to the monitoring path to offset the -30dB of gain. Even then, I am skeptical that the audio will sound the same, since everything you could not hear before was just boosted by +30dB of gain.
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
#29
Listening level is usually around 80dBSPL.
converters have -120dB dynamic & noise floor range. And 24-bit files have -144dB. The minimum recording level should be exactly the minimum audible... The maximum should be exactly the maximum tolerable. For example: Adam a7x pair, has a Max SPL of 114dB @ 1mt. 108dB @ 2mts. Minimum recording level should be -108dB. Recording level and Playback level should be 1:1 http://www.adam-audio.com/en/pro-aud...technical-data Recording level should be more than: -100dB. People record hot because loudspeakers are not hot, To compensate overcompensate. Recording a -6dB signal but listening at 50dB SPL, is not the same as listening at 110dBSPL. People loose the sense/perception of loudness when listening at low volume. When playback level is too low is not possible to detect errors as easy.
--->If you don't like what i wrote: Click: JuanPC Click: View Public Profile Click: User lists^ Click: Add to ignore list. Solved. |
#30
If everyone was forced to use real analog VU meters, we wouldn't be having this conversation because 0dBVU (which is -18dBFS) looks and feels "hot". |
Best Recording Levels | spaceman | Tips & Tricks | 102 | 11-26-2011 06:53 PM |
Low recording levels | Krish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-29-2011 05:11 PM |
Recording Levels | jawjam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 08-20-2004 01:32 AM |
recording levels | Graeme Oxby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 01-25-2003 12:06 AM |
Recording levels | nickair | Pro Tools TDM Systems (Mac) | 2 | 06-23-2000 10:11 AM |
