Old 12-18-2010, 01:58 PM
Uneek Uneek is offline
Default Problem with MIDI Notes
This is probably an easy fix but I can't figure it out. When I record midi notes, for some reason it is adding additional 1/8 notes at the start of the notes I recorded. Does anyone know what would cause this?
Old 12-18-2010, 08:21 PM
Default Re: Problem with MIDI Notes
Personally, I would focus on the MIDI Controller as the resolution to your problem.
Aaron Mulqueen - 001 HD Native
Old 12-19-2010, 06:35 PM
Zackdh89 Zackdh89 is offline
Make sure you don't have usb and midi cable in the one keyboard. The ports are mirrored so if you have the two cables in it will trigger midi notes twice.
Old 12-20-2010, 06:37 AM
Steve@ZooWest Steve@ZooWest is offline
As a temporary work-around, try selecting the area with doubled notes, then:
Event/Remove Duplicate Notes
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 12-20-2010, 08:30 AM
DigiTechSupt's Avatar
Since we don't know which controller you're using, I'm guessing that whichever one it is is set to output on multiple zones. Just disable all zones but one and the problem should go away.
Avid Audio Tech Support
Support FAQ
MIDI notes problem manyrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-10-2012 09:16 AM
Problem with wrong MIDI notes Kuwajleen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-08-2008 03:47 PM
RE: Doubled midi notes- Problem Solved gw sound Pro Tools TDM Systems (Mac) 4 05-23-2007 08:58 AM
MIDI "Select notes" tool problem GeneOuse Pro Tools TDM Systems (Win) 2 04-27-2005 12:27 AM
MIDI notes problem Superclock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-15-2002 09:36 PM
