Here\'s the Scam!
Ok, Can't afford a new Dualie G5 with 64 bit processing and the '002 desk / rack, I'm stuck with my '001. Don't get me wrong, I love it!
I have a PowerBook 1Ghz. If I were to invest in a MBox, would I be able to mix sesions in PT LE 6.7 from sessions recorded in '001, in 6.7 MBox LE should I buy one of these little babies? On the proviso that MBox supports 6.7. Caio Skip G4 533 DP, '001, OSX.3.4, PTLE 6.4 |
Re: Here\'s the Scam!
You can work with sessions from the Digi001 without a problem so I would definitely go for the Mbox. You just need to make sure you are using a firewire HD with your Powerbook.
- Jason |
2nd attempt at replying.
I'm sure that Digi will incour lots of abuse from not keeping the faith with '001 users in this forum. If LE6,7 works with Mbox, on G4 chips whats the delay with '001 users. I havn't done my homework properly, but I'm assuming MBox supports LE 6.7. Correct me if I'm wrong. If it does, can i load my PB 1Ghz & my G4 PowerMac with the same software? skip |
"Most of it has already come and gone from when the announcement was first made. However, just because 6.7 is being released doesn't mean that 6.4 won't work anymore with your 001 - they haven't broken anything for you"
Im sorry but this has yet to be seen |
I'm sorry, but your post doesn't make any sense.
Either your 001 works with 6.4 now or it doesn't, how is this "yet to be seen?" |
As for why...it probably has something to do with the fact that the 001 has been discontinued for some time now, and isn't compatible with any of the currently-available Apple computers. I think that most users would rather see Digidesign putting their efforts into development of new and current products rather than discontinued systems running on discontinued computers. And it's true, there's nothing "yet to be seen"...it works now, what could change that would make it not work later? -Duardo |
So I guess the question is whether Digi did something intentionally to 6.7 to make it not run on the 001 (where it would have otherwise), or did they *not* do something to 6.7 that would have made it compatible with the 001 (that would have taken some effort, or would have been impossible for hardware reasons). Unless you know the 001 REALLY well from an engineering (electrical as opposed to audio)standpoint, you'll probably never know.
Gordon in Austin Mac G4 Digital Audio 466MHz MacOS 9.2, 1.25GB RAM, 110GB HD digi 001, PT LE 5.3 |
Digi did intentionally make 6.7 not support the 001. 6.4 was the last version that will support the 001 and MIX systems. They have to cut support somewhere, and they chose to do it there. They're moving along, like all buisinesses do. Apple doesn't still support the old Performas, but i don't see anyone questioning that desicion.
HD Pack 8, Where is it? How to get it? Is it a scam? | Stereosurfer | Pro Tools TDM Systems (Mac) | 4 | 08-21-2009 04:31 AM |
ilok a scam? | master-ceo | General Discussion | 18 | 07-01-2007 10:52 PM |
Is this a Mac G5 scam??? | borntoplese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-10-2005 03:16 AM |
Is this a scam?????? | billy the kid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-20-2003 09:34 AM |
