ProTools losing MIDI ports
I am using a MIDIPlus 2x2 for MIDI in/out. In MIDI Studio I have set up -- StudioLogic 880 keyboard (SL880) with input on MIDI2x2 [Emulated] = port #1 IN on MIDIPlus. -- Korg Triton-Rack with output on MIDIOUT2 [Emulated] = port #2 OUT on MIDIPlus. MIDI works fine with Instrument and MIDI tracks.
But if I a) exit and restart Pro Tools the port assignments have disappeared b) use MIDI Studio to Export the configuration to a DMS file and then Import the DMS file the port assignments have disappeared. Has anybody else seen this? Any ideas what I am doing wrong? Or is this a Pro Tools bug? |
Re: ProTools losing MIDI ports
The only reference to a DMS file I can find is this: "what is a .dms file? A Disk Masher image file is encoded with compression specifications similar to the standards implemented into Amiga disk images. ... There is a version of the Amiga Forever software developed for computers running on Mac platforms, and there is also a version for Microsoft Windows-based systems." |
To the OP - the MIDI Studio Setup should be persistent across sessions without having to load a .dms file. The only thing I can think of is to delete the default DMS profile located here: C:\Users\YOURUSERNAME\AppData\Roaming\Avid\Pro Tools\DefaultProToolsMIDISetup.dms and reconfigure MIDI.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Sorry. I am on Windows 10 64 bit running Pro Tools 2018.
And the problem(s) are that after setting up a MIDI port configuration in MIDI Studio (and having Pro Tools Instrument and MIDI tracks working just fine) then a) after exiting and restarting Pro Tools the port assignments are missing b) after saving the port configuration using MIDI Studio Export to DMS file and then importing that file the port assignments are missing. |
Hi, I'm running into this issue as well.
I'm running ProTools 2019.6 on a Windows 10 64-bit PC. My audio interface is a Behringer UMC1820 and my MIDI interface is an iConnectivity Mio10. Again, when restarting ProTools, my custom session template will forget the MIDI ports for all of my instruments in my MIDI studio. Has anyone come up with a solution to this problem? I've tried deleting that .dms file in the roaming folder. Should I try deleting everything in that roaming folder instead? Thanks, Joshua |
ProTools 8.0.4 doesn't send MIDI to Yamaha S90 ES; midi out ports [Emulated] | bbirney | Pro Tools M-Powered (Win) | 8 | 05-19-2018 06:58 PM |
MIDI Virtual Ports not showing up in MIDI Controllers (8.0.5) | emiliojazz | Pro Tools M-Powered (Mac) | 0 | 02-18-2013 12:03 PM |
Three MIDI ports on DIGI 002R within MIDI studio Setup | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-18-2010 04:57 PM |
003 midi ports not there in midi studio setup? Unable to record midi now? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-22-2009 12:06 AM |
virtual midi keyboards, cable/ports & protools | darigan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-26-2006 12:24 PM |
