Co instal pt 12 , 11,10 on capitan is possible ??
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
Re: Co instal pt 12 , 11,10 on capitan is possible ??
Hi
Co-install on thesame drive and partition is only possible with 10.8.5 and PT10/12 or PT10/11. I a m sure someone will come here and say that they have it working but if you want to have a supported system and a working system then keep to the official Avid information which is the above alternatives. So NO to the El Cap co-install.
I wouldn't advice playing around with that stuff on the same partition and as we need to have our systems 100% supported since we live off making music and selling to A-List artists in the US I have never played around with those combos. I am afraid of mucking up something as PT is soo finnicky and easily irritated hehe We left PT10HD the day HD11 came out and haven't used or opened HD10 since that day 3 of our 4 Macs are still on OSX 10.8.5 and that has been awesome for us.
Then you have two versions of the Pro Tools application installed.
You would not have two versions of all the necessary files installed. Why? Because the installer application installs other files on your startup volume. If you install v11.x first, rename the app, then install v12.x, then launch v11.x, there is no guarantee that v11.x will either launch or operate properly since the most recent install was v12.x. If you install v12.x first, rename the app, then install v11.x, then launch v12.x, there is no guarantee that v12.x will launch or operate properly since the most recent install was v11.x. Try it at your own risk. Alternatively, just run v12.3.1. It's basically v11.3.1 with bug fixes and some new features (I/O setup), track commit, etc.
No.
PT's 10 is just not right. above 10.9.5 (Needed for other apps not using 10.8 and below (NI)) Use OS 10.8.5 instal and only upgrade OS to 10.9.5 if needed. OS's after that Pro Tools 10 wonks out. Keep a partition for PT's 10 (OS 10.8.5 ideally) (Needed for and sessions with SD2 files and ultra-vintage session needs. Avid really needs to get the import-session conversions current.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Possible? Yes.
Supported? No. Feasible? Perhaps not.
W-7 Pro Anyone using sp1? Update before instal? | aka21stCentury | Windows | 10 | 05-30-2011 01:37 PM |
lost instal CD | agentKrowka | Pro Tools M-Powered (Win) | 1 | 06-17-2009 06:06 AM |
help! can't instal ProTools 7.4 | thevoidband | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-05-2008 01:10 PM |
reason instal ? | halfguard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-25-2004 08:54 PM |
