Re: Please Help | Issues with I/O Constantly
Hey Stellarmas.
No worries. I was just curious as to what may be different at your location. Can you read the tag on the device? Probably located near the power cord. It may list the voltage and frequency. Did you buy it locally? You could ask the manufacturer about known issues, or perhaps verify that it should work with what you have etc. I took a quick look and it appears that your electrical system runs at 50 Hz. Also, I saw a short known issue with audio above 44.1 Khz. Did you try 44.1K? HTH. Steve. |
Hi, does anyone have any ideas on how I can fix this issue as it is still ongoing?
Thanks |
Are you using the Pro Tools aggregate device as the playback engine? If so, change it to the Saffire.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Hi dude thanks, no I am using the Saffire as the playback engine as you said. I definately feel like its the Saffire software and Pro Tools software conflicting with each other as I always get pop-ups when opening Pro Tools that the I/Os have changed when I have actually changed nothing myself! |
Another thing to try is option-click the Default button in I/O Setup to reset everything. In the past that has cleared up I/O strangeness here.
#16
Yeah, I have done that loads of times man but like i said next time i open Pro Tools again it says there has been changes to the IO's even though I haven't changed a thing so that's why I think it must be a conflict between Pro Tools and Saffire Mix Control although I am unsure what to do about it. Could someone send me images of their Pro Tools I/O layouts that I could save as a template and see if that helps at all? All I normally use through my Saffire is the two mics inputs so it's a basic setup. Thanks |
#17
Hey everyone, last ditch effort here as this issue is 100% keeping me from recording any music
The best and clearest way i can describe this issue is this: My hardware device (Saffire Pro 24 DSP) can pick up the signal from my two mics with no issues as I can see the input meter rising The Saffire Mix Control software whch accompanies my hardware device can also pick up the signals from the two mics with no issues whatsoever My only issue is that Pro Tools does not pick up any sound input at all. I have tried various methods to fix this issue over a long period of time which has included deleting all the I/O paths and setting back to default and saving this and also changing my sample rate, making sure my hardware device is my Saffire, changing the Hz settings but nothing is helping. If anyone has any knowledge about this can they please shed some light on it! I would appreciate it alot as all I wanna do is record some music lol Just to add to this ---- my MIDI keyboard works fine and Pro Tools pick up the signal coming from it with no issues! Thanks, Paddy Last edited by stellarmass; 08-23-2016 at 04:39 AM. |
#18
Anybody out there think they can assist with this?
PT 10.3.7 crashing CONSTANTLY! | LSD-Studio | macOS | 6 | 11-30-2013 11:56 AM |
Axiom 49 issues unsolved!!! Settings constantly lost... | thisistruth | MIDI | 1 | 05-10-2011 07:26 PM |
PT5 crashes constantly on MDD G4. Please Help! | motord | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-28-2006 01:01 PM |
OT - CPU fan on constantly | neeel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-10-2006 11:56 AM |
Constantly | cmorey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-27-2001 08:30 PM |
