  #31
Old 03-25-2019, 09:55 AM
Default Re: 12 cores not being used equally (cpu errors)
Originally Posted by stevedresser83 View Post
Not talking about production or running VI's. Just purely mixing, sessions with lots of plugins. All audio with plugins. I wonder if anyone has ever done a DAW comparison in how each daw utilizes cpu usage, cores, ram, etc
They all suck at balancing cpu usage. You definitely should look into VEPro; I think there's a demo but you'll need a physical Steinberg or Vienna key as it won't work with the s/w version.
Jack
QAPLA!
  #32
Old 03-25-2019, 10:03 AM
If this is a 6 core hyperthreaded system you also don’t have 12 actual cores here. Obsessing about what CPU meters show with hyperthreading can be a trap.... you should not necessarily expect flat virtual core use.
  #33
Old 03-25-2019, 11:34 AM
stevedresser83 stevedresser83 is offline
im not obsessing about what cpu meter shows. I'm noticing that 3 out of 12 cores whether hyperthreading or not are being used, 15% of ram being used, and i'm getting cpu errors. I have a machine clearly not being utilized but protools is acting as if its completely maxed out. So i'm wondering what can be done about that.
Looking into VEpro now. Not sure if its really what I want for my workflow. I'd imagine to access all those other machines I will have to be working within VEpro interface. Could be nice though production
  #34
Old 03-25-2019, 11:57 AM
Work at a lower sample rate, lots of folks here have articulated why 192kHz is likely not needed. Fully optimize the system, every last thing done. Use freeze/commit. Test different plugins to find any bad actors. You can try disabling hyperthreading (results are very plugin dependent). Avoid long bus chains/deep stacking of plugins. Look at the specific AAE error you are getting and what other folks have done. VE Pro is an option (would only use for VIs).
You are getting CPU latency errors, the meters do not directly show processing latency. I would be doing all the above and not paying attention to what the meters show. Changes that reduce CPU errors may or may not change what you see in the meters.
  #35
Old 03-26-2019, 02:23 AM
LDS LDS is offline
Originally Posted by Emi View Post
...not even Pro Tools is needed, if you go this route.
I don’t get the implications. You don’t need Pro Tools to run 192kHz sessions.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
  #36
Old 03-26-2019, 05:43 AM
7Seas's Avatar
7Seas 7Seas is offline
Isn’t VEP mainly for VIs? I never dwelled into it because I understood that VIs were VEP’s thing. Will it work on plugins as well? Macos here...
  #37
Old 03-26-2019, 05:45 AM
the.engineer the.engineer is offline
https://m.youtube.com/watch?v=jGP7-bxPJXU
This is a good video to watch!
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon R9 280X 3072 MB | 256GB Samsung SM951 SSD Blade (PCIe) System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Sierra 10.12.6 | Pro Tools Ultimate 2018.10 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
James Welch
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #38
Old 03-26-2019, 10:29 AM
You also don't need pro tools to record, mix, run at 48 or whatever sample rate you want, you don't need pro tools to edit...you don't need pro tools, period...and I repeat, if you go that route.
If it's in its specs and I want it to run at 192Khz...it should run...and it does run...I don't understand having a feature that I want and the software gives it to me, but everyone else tells me you don't need it....what the....
I buy a Ferrari and damn it I cannot drive it everywhere at 300 km/h. It is obviously the fault of the car.
If you want to convince other folks here you need 192 kHz because it sounds better then provide some link to blind tests showing that. Surely with this debate running for decades that must have been demonstrated by now.... Oh there is no convincing proof? Well expect people to point that out when you claim there is a difference.
Problems operating at 192 kHz are largely a self inflicted problem.... want to try to get work done, I would be dropping the sample rate to 96kHz and testing stuff.
  #39
Old 03-26-2019, 11:13 AM
arche3's Avatar
arche3 arche3 is offline
Google Lavry papers on sample rate.
Sent from my SM-G975U using Tapatalk
  #40
Old 03-26-2019, 11:18 AM
Eric Lambert's Avatar
This is the one; what we've all been referring to:
http://www.lavryengineering.com/pdfs...lity_audio.pdf
Shortcut for spacing audio clips equally Unskirmisher Tips & Tricks 20 03-30-2017 03:14 PM
Problems when using all 4 cores vs. 3 cores hopelessennui macOS 1 02-03-2012 06:54 AM
Mac Octo 2.26: Almost no difference between 2 Cores and 8 Cores Hive Guy macOS 8 05-10-2011 11:05 PM
Not all regions normalizing equally jwolford macOS 14 05-07-2011 10:57 AM
better performance from 7 cores than 15 cores? stevesound macOS 4 03-30-2011 11:48 AM
