Old 05-07-2002, 01:15 AM
TIGERSHARK TIGERSHARK is offline
Default how do i slow playback of predefined .WAVs?
i successfully imported several .wav drum loops into ptf. however, i'd like to slow the tempo a little. i've tried a few things but it doesn't seem to affect the speed in which they're played back. any suggestions or am I out of luck and stuck with the 'sounding' tempos? [img]images/icons/smile.gif[/img] thanks!!
Old 05-07-2002, 01:21 AM
Default Re: how do i slow playback of predefined .WAVs?
sorry for the mistaken double-post. [img]images/icons/shocked.gif[/img] thanks for any replies. [img]images/icons/grin.gif[/img]
Old 05-07-2002, 01:30 AM
Bastiaan Bastiaan is offline
I think if noone answered to a thread, you can delete it yourself....by choosing edit (the paper&pencil icon) and check the delete box, for every message you posted there. A thread without any messages will disappear by itself.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 05-07-2002, 01:33 AM
the thing you are looking for is an audiosuite plugin called pitch 'n time. This is a standard digirack plugin. Some people arent too happy with the quality though....
What's that?
Bastiaan
Old 05-07-2002, 09:45 AM
clausiii's Avatar
clausiii clausiii is offline
No it´s not Pitch ´n Time. It´s Time Compression/Expansion in the Audiosuite menue. First select the region you want to work with, then use Time Compression/Expansion and change length. If you want to change length without pitchshifting, make a cross in the little white square.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-09-2002, 10:14 AM
thanks for the replies! [img]images/icons/grin.gif[/img] i tried using that feature but all i heard was gobbley-gook upon playback. [img]images/icons/frown.gif[/img] am i missing a step? (maybe i missed checking the white box) what sliders to i move to just slow it down. there seem to be a lot of options that aren't really clear to me. THANKS!!!
Old 05-10-2002, 08:14 AM
clausiii's Avatar
In most cases it works, when you set a new length time, the length you want, by double-click on the time on the right side -> the type new length.Do not use the sliders prmarily
But the real problem is, is when you change the length of a groove, your whole drums/percussions get longer. your "ISCH" snare makes after time expansion "IIIIISCHSCHSCH". That sounds not natural. Extreme changes will cause artefacts and maybe strange, distorted sound.
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-11-2002, 03:54 PM
Stone Knife Stone Knife is offline
You need to find the Digirack Plug-Ins Guide in the documentation and read the instructions. There are some complex interactions with the Compress-Expand tools (as there are with the pitch-shift ones) that will waste a lot of time until you understand what the controls do.
You can use the two tools: Compress-Expand and Pitch Shift together in different order to create some very useful stuff; but the time spent on finding out what you're doing will be a great investment. [img]images/icons/cool.gif[/img]
Old 05-11-2002, 04:11 PM
Rock_Artist Rock_Artist is offline
Shift-Space anyone [img]images/icons/smile.gif[/img]
Just wanna do music,
RA.
HTML code is On
Plays imported wavs, records new wavs, BUT WON'T PLAY NEWLY RECORDED WAVs cmoseman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-02-2008 11:20 AM
Playback of bounced wavs on XP neelhaq79 Pro Tools TDM Systems (Win) 1 10-09-2003 11:47 AM
how do i slow playback of predefined .WAVs? TIGERSHARK Digidesign Hardware & Software 1 05-08-2002 07:27 PM
slow playback muscmp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-25-2002 11:28 PM
slow playback sid rosen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-10-2001 12:47 PM
