Old 07-26-2014, 11:40 AM
propower propower is offline
Default New MOTU AVB boxes vs HD NAtive
If I were buying a system today - the new MOTU would get a VERY hard look at!
http://www.motu.com/products/avb/1248
Key features MOTU (using 1248 as example)
- Latency = 32 samples = 0.72ms @ 44.1. At 32 buffer in and out = 2.17ms
For reference - HDN = 3.35ms
- Thunderbolt connectivity (same)
- 14 analog in 18 digital, 8analog out 18 digital - (way more than Omni)
- Expandable under AVB (Ethernet) - (single CAT5 wire - how cool is this!)
- Controllable by WiFi directly - (some 3rd party solutions for AVID)
- Onboard mixer/dsp for monitoring if you want to (No AVID equivalent)
- Cost = $1500
Edits: --------------------
- No PTHD software -thanks Craig below (though ebay and ~$1400 can fix that)
- No Sync HD capability
- 32 track simultaneous I/O limit using PT (HDN is 64) Thanks to all below for clarifying
Of course how WELL it performs at low buffers, overall stability and somics have all yet to be seen but "on paper"... what does HDN have over this??
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT2019.x Orion Studio 2017, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 07-26-2014, 12:18 PM
Craig F Craig F is offline
Default Re: New MOTU AVB boxes vs HD NAtive
64 channels of I/O if using 4 HD I/Os or MADI I/O
Sync HD if you need to sync with older devices (2", VTR, analog console automation), or you want to use it's VSO capabilities
a HD software license
not that every one needs this, it's just what HDN brings that MOTU doesn't
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 07-26-2014, 12:22 PM
I always get tripped up on this part... If we assumed the user had an HD software license -
How many I/O channels would be seen using MOTU instead of AVID I/Os??
Old 07-26-2014, 12:35 PM
8dB.co.uk 8dB.co.uk is offline
32 Max.
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
Old 07-26-2014, 01:05 PM
JFreak's Avatar
JFreak JFreak is online now
Originally Posted by 8dB.co.uk View Post
32 Max.
Yes.
Non-HD software and 3rd party hardware is always 32 i/o max.
HDN comes with HD software and 64 i/o max (as in one box per system).
HDX is unlimited.
Janne
Old 07-26-2014, 01:21 PM
Originally Posted by JFreak View Post
Yes.
I assume you meant to also include:
- HD-Software and 3rd party hardware = 32 i/o max as well?
Old 07-26-2014, 01:32 PM
Which for post is fine.
Old 07-26-2014, 02:13 PM
JFreak's Avatar
Yes, either non-HD software or 3rd party hardware makes it 32 i/o max.
Janne
Old 07-26-2014, 04:39 PM
OK -
CONS...
32 i/o simultaneous vs 64
No sync HD
No HD software (though we all know where to buy that)
Unknown real world performance and sonics
VS
PROS....
Lower latency
AVB inter connectivity
Built in WiFi control
various relatively inexpensive i/o expansion boxes
Not too shabby so far...
Old 07-28-2014, 07:26 AM
RyanC RyanC is offline
Just to be specific, I believe that if you have more than 32 3rd party IO (up to 64?) PTHD will see all of it, but only allow you to route up to 32 in your IO window.
Which is another point, with HDIO's (or omni + aes) the number of IO's doesn't change when you change sample rates. Not sure what happens with the motu's but for interfaces that do that, it can be a hassle with naming and routing IO's and importing templates.
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 09:48 AM
Curious - MOTU Video Boxes mikevarela Post - Surround - Video 7 11-29-2010 05:50 PM
PT HD9 (running native with motu) running out of memory syMPh Pro Tools TDM Systems (Mac) 1 11-21-2010 08:34 PM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 08:58 AM
DIGI 001 and Motu 2048 MK II or Motu 24i+ Logic Audio cyril 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2002 10:08 PM
