Old 02-04-2011, 12:44 PM
grooveline grooveline is offline
Default using original mbox interface
anyone using the original mbox interface with PT9?
Have been reluctant to upgrade from 7.1 because of the need to purchase a new interface. I know Avid has stopped supporting this hardware.
PT9 seems to be compatible with more interfaces now. I know Avid still will not support the 1st gen MBox but will it work?
Anyone have first hand experience here?
Thanks!
Old 02-04-2011, 12:52 PM
Dism Dism is offline
Default Re: using original mbox interface
No drivers were written for W7.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 02-04-2011, 12:54 PM
I just found it is not supported but does that mean that I won't get help when I have a problem or does that mean forget it, not recognizable?
Old 02-04-2011, 12:56 PM
and now I'm reading not compatible. booooooo.
Old 02-05-2011, 05:03 AM
AndyJCP AndyJCP is offline
As one of the other posters mentioned, the problem is that Digi. sorry. Avid are not producing any ASIO driver for Windows7 and the original Mbox.
You could (!) have two solutions:
1) There seems to be a 3rd party ASIO driver for the mbox at http://www.usb-audio.com/. I have not tested it myself, but maybe you can try
2) You could maybe stay on WindowsXP (PT9 can run on XP if you're lucky) and use the WinXP ASIO drivers for the mbox.
I'm not sure if any of those will work though...
The best way would be to get a new interface (or to use your onboard soundcard if playback is enough for you).
Cheers, Andy
Old 02-05-2011, 06:53 AM
I just tried the Demo driver from usb-audio and it works with my Mbox with PT9 on Windows7 (64bit).
Seems good.
Old 02-05-2011, 11:43 PM
DJ Hellfire DJ Hellfire is offline
Just get a new interface. You can get an Mbox for $100-150 on eBay!
www.HellfireBeats.com
Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49
Pro Tools 2018.10
Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.6
13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.6
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.6
Second hand original Mbox vs new Mbox 2 Mini east 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-09-2012 05:31 PM
will pro tools 9 work on original Mbox interface bissodj Pro Tools 9 17 03-01-2012 10:56 PM
PT 9 and the original Digidesign Midi Interface. hotmits Pro Tools 9 2 02-29-2012 04:11 PM
New Mbox 2 Pro 7.4 install - dead - 7.1 was fine with original Mbox - HELP! gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-25-2008 07:18 PM
MBox MINI or MBox Classic (Original) epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-25-2007 03:44 AM
