  #31
Old 09-30-2017, 06:12 PM
dennisdenizendnessis dennisdenizendnessis is offline
Default Re: "AAE error - 536870192 was encountered"
Have been dealing with this same issue. And while my computer settings recognizes a Pro Tools I/O Aggregate, the "Hardware" window from the "Setup" tab does not. From what I hear it sounds like this is a compatability issue between the new OS and the Mbox Mini 3 -- has anyone replaced their interface and successfully remedied this issue?
  #32
Old 09-30-2017, 07:03 PM
What hardware/setup “tab” are you talking about? Screenshots or exact descriptions.
There is not any “Setup” or “Hardware” dialog you should be using to get this working with Pro Tools.
Does Pro Tools let you select that aggregate device in Setup>Playback Engine
"Could not complete the import audio command because DAE error 35 was encountered..." Sean_tiburon macOS 1 02-29-2012 07:03 AM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
"DAE error -13001 was encountered" topix Pro Tools M-Powered (Win) 0 01-23-2011 01:00 PM
LE 8.03 on Vista Home SP2 Startup, get error: "DAE error -6006 was encountered." anhughes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-09-2010 09:12 AM
