Old 07-14-2014, 07:07 PM
clarkchaz1988 clarkchaz1988 is offline
Default cracking an popping on plugins with pt 11
I'm coming from 8.05 and just downloaded the pt 11 trial. When ever I load a plugin such as xpand or boom i get this static and cracking sound when I play notes. I know it has something to do with the audio engine because when ever I adjust the buffer to 1024 it goes away. In 8.05 I was running smooth for years with the buffer at 512 and 256 occasionally and never ran out of cpu power or anything when using plugins ,granted I was running on 8 gigs of ram as opposed to 4( one of memory sticks just died on me). I did all the optimizations but to no avail.When I'm playing back audio from a old session, pt 11 does just find and I load channel strips and everything with no issues but the vi's just aren't working for me.
SiSoftware Sandra
ID
Host Name : Owner-PC
Workgroup : WORKGROUP
Computer
Model : GigaByte P67A-UD4-B3
Chassis : GigaByte Desktop
Mainboard : GigaByte P67A-UD4-B3
BIOS : Award (OEM) F3 03/31/2011
Total Memory : 4GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (4C 3.69GHz, 3.7GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : Intel Core (Sandy Bridge) DRAM Controller 100MHz, 4GB DIMM DDR3 1.33GHz 64-bit
Memory Module(s)
Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5)
Video System
Monitor/Panel : Hewlett Packard HP w2408
(1920x1200, 24.0")
Video Adapter : NVIDIA GeForce 7600 GT (12PS3.0, 5VS3.0 561MHz, 256MB DDR3 1.4GHz 128-bit, PCIe 1.00 x16)
Graphics Processor
Storage Devices
WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) : 466GB (E:)
Seagate ST3360320AS (360.1GB, SATA300, 3.5", 8MB Cache) : 335GB (C:)
WDC WD5000LMVW-11VEDS3 (500.1GB, USB3/SATA300, 5400rpm, 8MB Cache) : 466GB (G:)
ATAPI iHAS124 B (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
Hard Disk (E:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache)
System Reserved : 100MB (NTFS)
My Passport (G:) : 466GB (NTFS) @ WDC WD5000LMVW-11VEDS3 (500.1GB, USB3/SATA300, 5400rpm, 8MB Cache)
Hard Disk (C:) : 335GB (NTFS) @ Seagate ST3360320AS (360.1GB, SATA300, 3.5", 8MB Cache)
Optical Drive (D:) : N/A @ ATAPI iHAS124 B (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Gigabyte P67 LPC Controller
LPC Legacy Controller 1 : ITE IT8728F
Audio Device : Gigabyte Cougar Point High Definition Audio Controller
Audio Device : VIA VT1720/4 Envy24PT PCI Multi-Channel Audio Controller
Serial Port(s) : 1
Disk Controller : Gigabyte Cougar Point 4 port SATA IDE Controller
Disk Controller : Gigabyte Cougar Point 2 port SATA IDE Controller
Disk Controller : Gigabyte 88SE91A3 SATA-600 Controller
USB Controller 1 : Gigabyte Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : Gigabyte Cougar Point USB Enhanced Host Controller #1
USB Controller 3 : VIA VT6212 USB Controller
USB Controller 4 : VIA VT6212 USB Controller
USB Controller 5 : VIA VT6212 USB EHCI Controller
USB Controller 6 : Gigabyte Renesas Electronics USB 3.0 Host Controller
USB Controller 7 : Gigabyte Renesas Electronics USB 3.0 Host Controller
FireWire/1394 Controller 1 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Wireless Adapter : D-Link DWA-140 RangeBooster N USB Adapter(rev.B2) (802.11g (ERP), AES-CCMP, 24Mbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.3
Old 07-14-2014, 07:20 PM
zedhed's Avatar
zedhed zedhed is online now
Default Re: cracking an popping on plugins with pt 11
The 'Instruments' are a separate download for PT11.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 07-14-2014, 07:27 PM
I know and when I load xpand on a instrument track it'll play fine and I can record a couple of instrument tracks and get some melodies going then i'l load another plugin and the system starts making the plugins sound sluggish and I hear this cracking sound whenever i hit a note.
Old 07-15-2014, 10:52 AM
The Weed's Avatar
The Weed The Weed is offline
1) Your RAM is Dual Channel and to take advantage of that, you need 2 matching sticks.
2) The minimum RAM requirement for Pro Tools 11 is 8 gb and 16 is preferred.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-15-2014, 11:07 AM
Yes memory is clearly suspect. Also I hope you are only using the WDC My Passport drive for backup or archiving, those drives are toxic for Pro Tools audio/session use.
Is your system fully optimized? Done every last thing? Disabled WiFi etc? Do them all for now, exactly as documented regardless if how silly seeming or inconvenient.
You may have ignore errors set in the playback engine settings, once you fix the memory (and Disk?) uncheck that and see what exact errors get thrown if any.
Old 07-15-2014, 11:42 AM
Yeah I have the passport drive for my sample libraries and I've been using my the Western Digital 500 gb for my audio for the last few years. I've done all of the optimizations as well. I'm going to go buy 2 8 gb memory sticks and see how it turns out. I never have the ignore errors box checked and I rarely get errors. So you guys think that my memory is the culprit?
Old 07-15-2014, 01:54 PM
Everybody is telling you your memory is suspect. Nobody can tell you for sure what is causing your problem. Whack the closest mole, and repeat until the problem is cured. Then you tell us what the problem(s) actually was.
Recheck all the optimizations are still properly done.
Regardless of the current problem I would not use those Passport drives for anything besides backup. If they will fit I would replace the system drive with a 1TB Samsung Evo SSD and put samples there.
protools popping and cracking sound. finaly solved LONDIN Pro Tools SE and Essential (Win) 11 11-29-2012 12:31 PM
Robotic cracking and popping sound. fretcruiser Windows 11 11-04-2012 01:05 PM
Popping and cracking using adat in (003r) geekkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-31-2010 04:12 PM
Cracking and extreme noise in LE 7 atomicwave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-19-2007 02:48 PM
GETTING RID OF POPPING OR CRACKING NOISE coleslaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-24-2002 06:24 AM
