Old 02-24-2014, 11:33 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: 11.1.2 quits nearly everytime i close a session
Originally Posted by pjthorpe View Post
You are not alone. I am also having weird (intermittent) crash problems, it sort of correlates to when I close a session. I am not using any cloud programs. I am using Window 7. Pro tools 11.1.2
I am using (latest version of all 24th Feb 2014): Superior drummer, EZmix, Waves (CLA artist, L3 multimaximizer, Kramner Tape). M-audio ultra 8R.
I have un-installed and re-installed all drives and programs.
I will brake it again tonight and get an error report.
Anyone else having these weird issues?
Hi pjthorpe!
I don't use any of your plugins, but i have also some other Waves plugins in my session. But i don't really belive that this is the reason, so many people use Waves plugins.
I use McDSP, PluginAlliance, PlugAndMix, IKMultimedia, Avid, NomadFactory as far as i can recall it...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 02-25-2014, 08:52 AM
pjthorpe pjthorpe is offline
OK so it crashed on my first time (without using short cut commands). But then I couldnt get it to crash again.
I had about 8 tracks. Superiror drummer, EZmix, Waves plugins on the go.
I have an error report but it is too big to attach. How do people share this info on here?
OS : Windows 7 (SP1)
Sequencer :Pro tools 11.0.1
SOUNDCARD: M-audio ultra 8R (main unit), M-audio FW1814, M-audio fast track pro
CPU: Intel Quad core Q6600
Motherboard: MSI P45 Zilent Socket 775 Motherboard
RAM: Kingston HyperX 8GB (4 x 2048MB) 1066MHz PC2-8500
plugins: Superior drummer, EZmix, Waves (lots)
soundcloud.com/peter-thorpe
Old 02-26-2014, 06:39 AM
avasound avasound is offline
+1
Old 02-26-2014, 06:45 AM
Southsidemusic's Avatar
Hey Pjthorpe
Just split up the report into 2 or more posts and post them under eachother.
That is how we did it and seen others do the same.
Best Regards
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-27-2014, 12:06 AM
clausiii's Avatar
well, i can´t reproduce it everytime, but i think it has something to do with the T-Racks plugins (in my case). as long as i have none of them inserted, everything is always normal, with them inserted PT can´t close a session without quitting..., but not everytime, sometimes it does, sometimes not...
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
  #16
Old 02-27-2014, 08:07 AM
Close the TRacks gui and you should be good. I find if I leave any open then I have problems.
Jack
QAPLA!
  #17
Old 02-27-2014, 08:10 AM
clausiii's Avatar
the GUIs are all closed.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
  #18
Old 05-14-2014, 03:33 AM
Dj-Ike Dj-Ike is offline
Title says it all, PT quits nearly everytime i close a session. It happens since version 11.1.
I trashed preferences aso, but it didn't help.
Some sessions do not force quit PT after closing them, some do.
And some sessions do both, closing normal (keeping PT alive), or force quit PT.
Until now i couldn't figure out, what's the reason behind it. It also doesn't matter if i use plugins or not.
Yes, i do know that i have an unsupported OS, 10.9.1, but it happend with 10.9.0 also.
I don't blame Avid, i just want to know if anyone else has this problem.
+1
Music is the Message
  #19
Old 05-14-2014, 06:43 AM
demodigi demodigi is offline
About T-RackS plug-ins, there is a "crash" bug for a long time (at least since v4.2). I notified it many times to IK (it is better in many situations since v4.5) but still there on the last v4.6.
To reproduce this bug (at 100% here) :
1/ open T-RackS GUI
2/ move some knobs or buttons (or recall a preset)
3/ (while GUI is opened) remove the plug in or replace this instance by another plugin or close the session
(NB : if you skip step 2/ there won't be any crash)
Workaround : As musicman691 said, to prevent from having this bug, close the GUI before quitting PT or swapping/removing T-RackS plug-in.
Other info : after having such a crash with a particular session, I also figured out that the "WaveCache.wfm" file of this session is corrupted.
-> Try to trash this file (it is a temp file so it is safe to delete) and see if you still have so many PT crashes when quitting.
Also did you repair system disk permission (I usely do this when I have too much consecutive app crashes) ?
Otherwise try to clean PT prefs.
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD)
MacMini (Core i7 Quad@2,3GHz RAM16GB SSD)
PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP)
PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP)
PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD)
PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD)
RME UFX (USB2 with MM and Firewire with MBP)
+ Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1
Session crash at same point everytime plus BSOD when I force close. Very peculiar! trevorcwilliams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-12-2012 05:06 PM
Just reinstalled PT 8 and now for some reason everytime I close and reopen PT.... Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-06-2010 09:51 PM
PTLE 7.0 Quits on "Close Session" Command RMW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-23-2006 08:16 PM
pro tools crashing everytime close session crizdee Pro Tools TDM Systems (Mac) 8 10-19-2005 10:28 AM
computer freezes everytime I close a session??? dchapp33 Pro Tools TDM Systems (Mac) 2 03-14-2005 07:02 AM
